Author Topic: Waypoints will not save to card.  (Read 23406 times)
Offline zdriver
  • Unit(s): 898c si & 597c hd
« on: January 25, 2014, 01:46:57 PM »
  I am doing everything right ( I think), but exporting all data to my sd card is not working. It only loads maybe  2/3 of them.
  Any ideas?
Offline George
  • Software: Always up todate
Re: Waypoints will not save to card.
« Reply #1 on: January 25, 2014, 04:40:49 PM »
Zdriver
Not sure if any of this will help.
How big is your card?
Have you checked your card to see how full it is?
Is your card now in the protected mode?
George
Offline zdriver
« Reply #2 on: January 26, 2014, 07:17:00 AM »
 The card is an 8gb. I removed everything from the card before I exported all waypoints.
 No, it isn't locked.  It seems, not sure, but it is only saving waypoints that are labeled by default. It is not loading waypoints that I have renamed. >:(
« Reply #3 on: January 26, 2014, 03:37:52 PM »
Do you have another SD card to try?
What version software are you running?  Are you using the waypoint management?
« Reply #4 on: January 26, 2014, 06:08:08 PM »
Try taking a snapshot (even if it's in full Simulator)..
This will tell you if the unit is writing to the card...
Offline zdriver
« Reply #5 on: January 27, 2014, 05:30:12 AM »
I was on version 5.7. I tried one sd card and it loaded 18 points. I tried another card and it loaded 2. One was from yesterday and the other was the simulation snapshot.  I formatted a card, exported all waypoints and saved tracks.  I deleted all waypoints on my 597, inserted my card, "SAVE ALL WAYPOINTS AND SAVED TRACKS?"---YES...It loads one saved track.
What is waypoint management?
« Reply #6 on: January 28, 2014, 02:32:49 PM »
Which unit are you trying this on?
What software version is it (or both units) running?
When you formatted the memory card, what File System did you format it to?
When you say: “I deleted all waypoints on my 597, inserted my card, "SAVE ALL WAYPOINTS AND SAVED TRACKS?"---YES...It loads one saved track.”, was this on the same unit?
Last post October 09, 2009, 03:55:58 AM
by kucai
Last post April 29, 2010, 09:21:23 AM
by kskloss
Last post October 18, 2011, 07:32:58 AM
Last post December 22, 2011, 10:48:51 AM
Last post April 23, 2012, 08:52:05 AM
Last post October 20, 2014, 08:45:56 AM
Last post April 14, 2016, 11:08:48 PM
by CamoHunter
Last post October 05, 2021, 11:16:34 PM
