Author Topic: waypoints on SD card  (Read 12863 times)
Offline Rocketman783
  • Unit(s): 798,788
  • Software: 4.51,4.60
« on: April 03, 2010, 09:26:45 AM »
 I have waypoints on a SD card identical to what is already in the depth finder and interlink system what will happen when I insert the card? Will it add the waypoints so that I end up with two of every waypoint, which I don't want? Another question, if I want to delete the waypoints on my SD card, in which folder -Matrix, Record, Snapshot, Profile - are they stored? Thanks for any help.
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: waypoints on SD card
« Reply #1 on: April 03, 2010, 03:14:45 PM »
Hi Rocket,
the Nav Data is stored in the Matrix folder.
Record --> Recordings
Snapshot --> Snapshots
Profile --> Unit information
Regards / Harry
YES,......
WE SCAN!
« Reply #2 on: April 08, 2010, 02:25:42 PM »
Rocketman,
As long as those waypoints on the SD card have the same name, icon and coordinates the unit will tell that XX waypoints are found but that there is no new Nav Data and not load them again.  Now if you happen to have named them… the unit considers them as new and different waypoints and so will load them into the unit.
Offline kskloss
  • Unit(s): 797
« Reply #3 on: April 28, 2010, 10:12:36 AM »
I've been working with Humminbird PC and have added dozens of waypoints into it then saved them to an SD card.  Nothing happens when I insert the card into the unit though.  What steps am I missing?
« Reply #4 on: April 28, 2010, 01:40:34 PM »
How did you “save” them to the SD card?
If you used the “Save as…” function than you saved a *.gpx file to the SD card which the unit cannot use.  You have to use the “Upload” function to the SD card so that HumminbirdPC will convert the data to our *.HWR format, make the correct file structure on the SD card and also name the file correctly (DATA.HWR).
Offline kskloss
  • Unit(s): 797
« Reply #5 on: April 29, 2010, 09:21:23 AM »
You're right on the money!!  Thanks for the help.
Last post April 04, 2010, 07:31:41 AM
by Jolly Roger
Last post November 09, 2010, 06:47:58 PM
by FuzzyGrub
Last post February 19, 2011, 06:31:01 AM
by stillbear
Last post October 18, 2011, 07:32:58 AM
by ITGEEK
Last post April 08, 2012, 06:48:06 PM
Last post April 22, 2012, 08:31:25 PM
by cfleague
Last post October 24, 2013, 09:55:58 PM
by Clackerbuzz
Last post February 28, 2014, 09:58:43 AM
