Author Topic: Download Failure when trying to save way-point from 787 to SD card  (Read 12383 times)
Offline gibsond
  • Unit(s): 728 and 898si
  • Accessories: Interlink
When trying to save way-point to SD from 787 I get an download failure. I Used the instructions from this forum to try this. Can someone help me out? I have a 4Gig SD card, is that to big?
Re: Download Failure when trying to save way-point from 787 to SD card
« Reply #1 on: December 07, 2011, 11:54:37 AM »
Which model “787” unit is this (we have made several different ones) and what is the software version?
It could be that the unit will not accept an SDHC type memory card, so you should try a smaller SD or MMC type memory card (less than 2GB in size).  Be sure and format the memory card before trying.
Offline gibsond
« Reply #2 on: December 08, 2011, 08:04:29 AM »
787 c 2    and I don't know what version it is I guess what ever came in it? How do I tell ?? What do I need to do to format the card?
« Reply #3 on: December 08, 2011, 09:26:36 AM »
I would confirm the software version in your 787c2 unit first.  If it is version 3.240 or lower that SDHC card you have will not work properly and you would have to end up getting a smaller capacity SD version memory card.  To check your software, follow the directions posted here:
http://forums.sideimagingsoft.com/index.php?topic=11.0
Offline gibsond
« Reply #4 on: December 22, 2011, 08:38:26 AM »
Thanks for the help Greg. The smaller card worked fine..
« Reply #5 on: December 22, 2011, 10:48:51 AM »
Update the software in your unit and you may be able to use that larger 4GB SDHC memory card in your 787c2 unit.
Last post October 09, 2009, 03:55:58 AM
by kucai
Last post April 23, 2012, 08:52:05 AM
Last post May 22, 2012, 12:40:11 PM
Last post January 28, 2014, 02:32:49 PM
Last post October 20, 2014, 08:45:56 AM
Last post April 14, 2016, 11:08:48 PM
by CamoHunter
Last post September 09, 2018, 04:29:40 PM
by wapati
Last post October 05, 2021, 11:16:34 PM
