Author Topic: How Do You Save Data from SD Memory Card ?  (Read 15140 times)
Offline iowafuzz
  • Unit(s): 898c si
« on: April 21, 2012, 09:40:52 PM »
I have looked and googled and can't find anything on how and where to save material from my SD card.  Went out a couple days ago and played with recording images.  Everything went great.  Downloaded Hum Viewer on my PC and was able to view the recordings I took without a problem.  Now the Problem - How do I save these recordings to my PC so I can delete them from the card?  Can't find how to do this.  Can someone point me in the right direction?
thanks, iowafuzz
Offline Patty
  • Unit(s): 898c SI
  • Software: 6.4??
Re: How Do You Save Data from SD Memory Card ?
« Reply #1 on: April 21, 2012, 09:45:35 PM »
I THINK you can copy and paste off the card itself... But PLEASE don't Take my word for it, Iam am computer dumbliterite.... :)
curious myself if there is a proper way to do it... which i'm sure there is....
« Reply #2 on: April 22, 2012, 10:28:29 AM »
It is a simple computer process as with any data.
Here is what i suggest:
1) create a file on your computer (something you can identify with like Sonar Recordings.
2) then make a sub file called (use date) or (lake name) or however you want to identify the recording
3) copy the sd card over to the file you created.
reference the link to a fourm explaination.  http://forums.sideimagingsoft.com/index.php?topic=937.0
« Last Edit: April 22, 2012, 10:30:06 AM by sonar2000 »
Offline iowafuzz
  • Unit(s): 898c si
« Reply #3 on: April 22, 2012, 07:33:51 PM »
 :D
Thanks for the help.  Got it to saved on PC and can now delete from SD card.
iowafuzz
« Reply #4 on: April 22, 2012, 07:40:24 PM »
iowa.  we use a 2g card and that holds a lot of 30 minutes recordings.
During the day if we are on the water all day we will make 5 or 6 recordings and then copy them to the laptop, delete the data on card and start the next reecordings.
I see you have it all figured out now. ;D
Good Job.
Offline iowafuzz
  • Unit(s): 898c si
« Reply #5 on: April 22, 2012, 08:05:25 PM »
Chuck,
I'm using a 4G card.  How long will that size record?
thanks, iowafuzz
« Reply #6 on: April 23, 2012, 08:52:05 AM »
Probably a lifetime?   ;D
It will depend on the recordings and if any snapshots or waypoints you send to it..
Generally speaking, you should be fine for a days run.
There are some post on the forum dealing with projected times.
You can use thew search tab at the top to find them.
« Last Edit: April 23, 2012, 08:57:50 AM by sonar2000 »
Last post December 22, 2011, 10:48:51 AM
Last post December 23, 2011, 06:10:37 PM
by LocDown
Last post February 27, 2013, 12:23:31 PM
by tigerfire
Last post April 30, 2013, 09:01:19 AM
by N9Phil
Last post January 28, 2014, 02:32:49 PM
Last post October 20, 2014, 08:45:56 AM
Last post October 05, 2021, 11:16:34 PM
Last post October 06, 2021, 10:24:47 PM
