Author Topic: Where to save data? zero line card or ScanDisk card  (Read 13869 times)
Offline GM
  • Software: None
  • Accessories: None
« on: October 03, 2021, 11:28:14 PM »
After a while reading several posts I am still confused about where to save data obtained during acquisition (AutoChart live with Solix, helix, apex, etc). So, I must buy Zero line cards for this or can I simply use regular card disks such as those ScanDisk ones. Also, I read that files saved to zero line cards are only in ACU format and those saved to other cards (eg. ScanDisk) are in SON/DAT format, is it right? Any hint is appreciated.
Best,
GM
« Last Edit: October 04, 2021, 08:49:19 PM by GM »
Offline GM
  • Software: None
  • Accessories: None
Re: Where to save data? zero line card or ScanDisk card
« Reply #1 on: October 04, 2021, 08:47:37 PM »
Sorry for bumping this one, I would appreciate your suggestions about this, thanks in advance.
« Reply #2 on: October 04, 2021, 09:09:15 PM »
You might also post you AutoChart questions in the AutoChart forum  ... some guys may not see it here in the General forum  ...
http://forums.sideimagingsoft.com/index.php?board=76.0
Here is some additional info :
http://forums.sideimagingsoft.com/index.php?topic=8122.0
Humminbird may also be able to help  ...
1-800-633-1468
Offline GM
  • Software: None
  • Accessories: None
« Reply #3 on: October 04, 2021, 09:19:23 PM »
Thanks for the quick reply! I will post it there.
« Reply #4 on: October 05, 2021, 11:16:34 PM »
All the AutoChart products must be used with the Zero Line card  ...
A regular SD Card is for Nav data, ScreenShots, or recording Sonar  ...
A recording on a regular SD Card can be imported into the AutoChart PC program to create custom maps  ... but must then be exported to a Zero Line card to be used in the HB unit as a map card  ...
« Last Edit: October 05, 2021, 11:21:58 PM by rnvinc »
Last post October 09, 2009, 03:55:58 AM
by kucai
Last post December 22, 2011, 10:48:51 AM
Last post April 23, 2012, 08:52:05 AM
Last post January 28, 2014, 02:32:49 PM
Last post October 20, 2014, 08:45:56 AM
Last post April 14, 2016, 11:08:48 PM
by CamoHunter
Last post May 23, 2017, 08:17:19 PM
by fshndude
Last post September 06, 2018, 04:47:06 PM
by JWN
