Author Topic: waypoints on sd card  (Read 15632 times)
Offline wrogersjr@aol.com
  • Unit(s): 898c Si Combo
  • Software: v6.490
« on: October 14, 2011, 08:36:15 PM »
When I  loaded new waypoints on my SD card from Hummingbird PC, it read "Not enough memory to hold new data". and I know it does not have no where near 3,000 waypoints.  Does anyone have any information on why it is telling me that it does not have enough memory when I know I have installed only around 300 waypoints????
Re: waypoints on sd card
« Reply #1 on: October 15, 2011, 05:41:22 PM »
Is it the sd card saying that or the unit...????
What size sd card?
chuck
Doc Stressor
  • Guest
« Reply #2 on: October 15, 2011, 06:02:06 PM »
You need to delete the existing waypoint held in the memory as well as all navigation data. The tracks and routes can take up a huge amount of memory depending on the settings you use.
If you don't delete the existing waypoints, you will find that any waypoints that are already in memory as well as on the SD card will be displayed twice.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #3 on: October 15, 2011, 07:34:52 PM »
are you saying we need to delete everything and start over?
Offline h8go4s
  • Unit(s): 898C SI
« Reply #4 on: October 15, 2011, 10:41:00 PM »
1. Open Windows Explorer.
2. Click on "My Computer".
3. Click on the drive where your SD card is located.
4. Right click and a drop-down box will open.
5. Click on "Properties" to display a graph showing the free space available on your SD card. If it's full or close to full, you need to delete some files or use a different SD card. If it has plenty of free space, then the SD card is not the problem.
  • Software: v6.490
« Reply #5 on: October 15, 2011, 11:29:56 PM »
I loaded 55 more waypoints on my sd card from hummingbird pc. Put the sd card in the unit. It read not enough memory to hold new data.It still loaded the waypoints . I don't understand why it would say not enough memory to hold data and still load the waypoints.
Offline LocDown
    • Fishing Videos
« Reply #6 on: October 17, 2011, 09:11:56 PM »
I think the "Not enough memory" is from trying to load saved tracks.
« Reply #7 on: October 18, 2011, 07:32:58 AM »
I've seen that message on my machine before.
You should periodically clear your current track.
The unit keeps recording the current track, even
if you're sitting still.
I don't know how much memory it can use or
how long it will record until it starts over.
Humminbird should allow the users to select
if they want a current track recorded or not.
It's a pain to keep clearing it.
Last post April 29, 2010, 09:21:23 AM
by kskloss
Last post November 09, 2010, 06:47:58 PM
by FuzzyGrub
Last post February 19, 2011, 06:31:01 AM
by stillbear
Last post April 08, 2012, 06:48:06 PM
Last post April 22, 2012, 08:31:25 PM
by cfleague
Last post April 20, 2012, 10:51:39 AM
by LBloch
Last post October 24, 2013, 09:55:58 PM
by Clackerbuzz
Last post February 28, 2014, 09:58:43 AM
