Author Topic: 1198 transducer not connected message  (Read 13099 times)
Offline bfischer62
  • Big Popi
  • Unit(s): 1198c
  • Software: 7.460
  • Accessories: none
« on: June 05, 2017, 08:40:53 AM »
 This Saturday I took the boat out for the year, went to power up my 1198 (3 years old) and got "Transducer not connected" message. When I went to the status screen, it shows that basically nothing was connected including the GPS.
 I tried disconnecting/reconnecting cables, I took the cables out of the connector holder and plugged them in individually with no luck. When we pulled the boat out, the cables & transducer appear to be fine.
 Any suggestions? In searching on these forums, it appears I may have a bad transducer. If this is the case why wouldn't the GPS still work?
Re: 1198 transducer not connected message
« Reply #1 on: June 05, 2017, 12:45:29 PM »
I would try to find someone else with a Humminbird unit that I could cross check on their boat.
« Reply #2 on: June 05, 2017, 10:57:22 PM »
Did you try Restore Defaults  under the Setup tab  ...??
Offline bfischer62
  • Big Popi
  • Unit(s): 1198c
  • Software: 7.460
  • Accessories: none
« Reply #3 on: June 06, 2017, 10:02:20 AM »
I did not, I will try this tonight - thanks
Last post April 12, 2012, 05:55:31 PM
Last post January 06, 2015, 09:45:58 PM
Last post April 19, 2013, 10:29:54 AM
Last post April 25, 2014, 02:31:50 PM
Last post August 30, 2014, 08:04:21 AM
by Steve Schmidt
Last post February 24, 2015, 02:16:14 PM
by CamoHunter
Last post July 16, 2015, 05:09:44 PM
by Silkwood
Last post March 25, 2016, 10:04:24 PM
by Bassman13579
