Author Topic: PROBLEM TRANSFERING FINISHED MAP TO chartselect MAP CARD  (Read 10747 times)
Offline KOROVA
  • Unit(s): 798ci
  • Software: 7.680
« on: February 14, 2017, 11:26:11 PM »
I HAVE AUTO CHART PRO AND I GET THRU ALL THE STEPS TO CREATING A MAP AND WHEN I DO THE FINAL STAGE OF CLICK ON LAKE MASTER UPDATE IT GOES THRU THE UPDATE  BUT BEFORE IT DOES THE FINAL TRANSFER A NOTE COME Up
ERROR: MAP PATH  N.A.
downloaded the Zero Lines Card europe and autochart pro data from ChartSelect
card is sandisk 32 gb
installed autochart on a 2. conputer - same error
unit is 798ci hd si combo
i created all folders from the manual
folder path is ok says humminbird support
files are ok says humminbird support
i tried two different readers witch i purchased separarly
i tried different usb ports
the card is not locked
it's sandisks micro extreme plus 32gb with sandisk adapter
i tried with and without adapter in the reader
Re: PROBLEM TRANSFERING FINISHED MAP TO chartselect MAP CARD
« Reply #1 on: February 15, 2017, 05:30:32 PM »
The map has to be written to a Zero Lines Card ... Not a chart select card......A zero lines card should have came with the software.
Maybe you just used the wrong terminology?
Offline KOROVA
  • Unit(s): 798ci
  • Software: 7.680
« Reply #2 on: February 16, 2017, 03:36:58 PM »
no, both is downloadable from chartselect - autochart and zerolines
https://chartselect.humminbird.com/store/autochart_pc?locale=en
« Reply #3 on: February 16, 2017, 03:54:48 PM »
This is something new to me ..... that you can create your own zero lines card with Chart Select.  It used to be a card that had to be purchased separately or it came with the purchase of Autochart PC software.
I hope you find your answers and please keep us informed if you find a solution.
Last post August 30, 2010, 01:48:09 PM
Last post April 27, 2012, 01:19:12 AM
by depark1
Last post August 08, 2012, 04:57:03 AM
by mako101
Last post September 09, 2013, 01:33:07 AM
by LocDown
Last post April 21, 2015, 10:00:18 AM
Last post October 05, 2015, 02:22:06 PM
Last post May 04, 2016, 04:01:27 PM
Last post December 09, 2016, 01:29:25 PM
