Author Topic: Humminbird ChartSelect to 1199  (Read 7766 times)
Offline cris
  • Unit(s): 1199CI HD SI, 958C HD DI
  • Software: 7.650, 7.660
  • Accessories: None
« on: May 04, 2016, 12:33:15 AM »
I have a HB 1199 and I downloaded my local lake from HB ChartSelect.  Do I need to set something up in my 1199 or does it automatically recognize it when I put it in the SD slot?  Also which slot do I use, or does it not make a difference?  Thanks!
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: Humminbird ChartSelect to 1199
« Reply #1 on: May 04, 2016, 10:44:38 AM »
Inserting an SD Memory Card into the Card Slot
SD Memory Card Slots
To insert an SD memory card:
1. Remove the SD memory card slot cover.
2. Position the SD memory card so that the label faces the left side of the unit, and insert the card into the slot. Press down on the card until it clicks into place.
3. Close the slot cover and turn the knob just 1/4 of a turn to close. Do NOT overtighten, as this will not improve water resistance and may damage the cover.
4. To Remove: Press the SD memory card into the slot and then release. The card will eject, and you can then pull the card from the slot.
NOTE: Do not leave the SD slot cover open. The slot cover should always be closed to prevent water damage to the unit.
• Auto Select: When you install the SD card in your control head, your Fishing System will
retrieve the chart and display it automatically.
• Chart Select: You can also choose which chart to display with the Chart Select menu option in the Chart Menu Tab. Choose Right (card slot) or Left (card slot) to select the SD card you’d like to use (see Chart Menu Tab: Chart Select).
« Reply #2 on: May 04, 2016, 04:01:27 PM »
When you encrypted your SD Card and downloaded the single lake map data thru the Chart Select program on the hb website ...your SD Card became a LakeMaster mapping card (but with only 1 lake data on it) ...
Using Mike's reference above - your unit will recognize the card now as a fully functional LakeMaster map card ... including the exclusive LakeMaster features available with all LakeMaster map cards ...
« Last Edit: May 04, 2016, 04:03:48 PM by rnvinc »
Last post February 04, 2015, 10:44:43 PM
Last post April 21, 2015, 10:00:18 AM
Last post October 22, 2015, 12:03:12 PM
Last post March 29, 2016, 12:42:55 AM
by Seabee
Last post May 31, 2016, 11:27:43 AM
by Fishin Impossibile
Last post December 09, 2016, 01:29:25 PM
Last post February 16, 2017, 03:54:48 PM
Last post March 07, 2021, 01:26:00 PM
by ezfishn
