Author Topic: 798 Ci Si Hd internal GPS loses connection  (Read 12404 times)
Offline txoutdoorsman53
« on: July 03, 2016, 05:52:14 PM »
My 798 CI SI HD is losing GPS connection as I am fishing sometimes. I have to power unit  off and back on for it to reconnect. Sometimes I have to do it twice. Is there a software issue or is something internally wrong. I have latest software version for my unit.
Re: 798 Ci Si Hd internal GPS loses connection
« Reply #1 on: July 03, 2016, 10:57:16 PM »
1st try Restore Defaults under the Setup tab ...
If that doesn't help ...:
Go under the Views tab and make the "Accessories test" view "Visible" ...
Then exit out of the "Menu" system and cycle thru the views until the "Accessories Test" view is showing ...
If the GPS is intermittently showing "Not Connected", it's most likely the internal GPS is failing ...
You can connect an external GPS antenna and override the internal GPS ...
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
« Reply #2 on: July 04, 2016, 07:54:27 AM »
had same problem...send it for inspection and the  tech guy told me the board has to be replace ..since then. never had any GPS lost or not been detected.
« Reply #3 on: July 04, 2016, 11:35:16 AM »
The other thing that can cause this is if the power to the unit is borderline .... The GPS is one of the first things affected by low power......Next time it happens, take a quick look at the voltage readout on the unit and let us know what it is.
Last post February 16, 2011, 10:30:04 AM
by kosmo
Last post March 07, 2011, 04:54:20 PM
Last post April 30, 2013, 03:52:45 PM
Last post October 08, 2013, 07:42:13 PM
by SaminVa.
Last post November 22, 2013, 09:03:19 AM
Last post May 09, 2014, 11:20:35 AM
Last post July 02, 2014, 01:32:59 PM
by alexpalmer1
Last post June 28, 2014, 12:18:01 PM
by slabbacks
