Author Topic: 898 loses colors  (Read 8726 times)
Offline CapeCod19
  • Unit(s): 898SI
  • Software: ?
898 loses colors
« on: June 27, 2014, 05:04:11 PM »
I have a 3 year old 898 plotter sounder.  It came with the transom mount transducer, which after some discussion, Humminbird determined was defective and replaced.  Since new, this machine has had a very odd habit of losing it's ability to properly display colors, except for a very faded yellow.  I also found the transom mount transducer to be so poor in performance, that I gave up entirely and put in an Airmar tilted element thru hull.  The thru hull reads bottom at all speeds and it provided much better resolution, at first.  Yesterday, the machine was back to it's yellow, all the returns on the sounder are yellow.  It does this after it's been on for the whole day, especially if there are a lot of fish around, no sarcasm, quite serious.  It's very frustrating.  I have reset the machine several times, it's good for a minute or so, but before I can even go back to all the settings, it's yellow again.  Any thoughts?  I'm not sending the machine back, I commercially fish and can't be without a sounder, so.....
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
Re: 898 loses colors
« Reply #1 on: June 27, 2014, 10:43:38 PM »
could it be a battery issue?  Have you checked this to rule it out?
Tell them I've gone fishing!
Offline CapeCod19
  • Unit(s): 898SI
  • Software: ?
« Reply #2 on: June 28, 2014, 10:29:54 AM »
Not a battery issue....running 14+ and everything is in good order.  This likely isn't simple, I've been doing this 24 years and have never seen anything like it and I've seen a lot.  I'm vry dissatisfied with this machines performance, overall, especially the greatly hyped but totally useless imaging feature, it simply does not work in almost any situation that is useful.  I fish exclusively in salt water, from 0-200'.
I saw a post where a guy had less return on the left w/side imaging, same here, sent the machine back, they said it was fine but gave me a free new ducer, didn't help.  I have installed many ducers, thru hull, skimmer and in hull, never had a problem.
« Reply #3 on: June 28, 2014, 11:45:08 AM »
The easiest test in these situations is to cross test the head unit and transducer with another SI unit...(testing your head unit in another setup...and testing another head unit on your setup)...
This gives a very reliable determination of whether the issue is your head unit or your xducer and/or boat wiring setup....
It doesn't matter which size SI unit setup you cross test with...
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
« Reply #4 on: June 28, 2014, 12:18:01 PM »
dang cape, was hoping it would have been a simple fix for ya.  good luck on the cross test
Last post February 07, 2010, 12:58:20 AM
Last post February 16, 2011, 10:30:04 AM
by kosmo
Last post March 07, 2011, 04:54:20 PM
Last post August 13, 2011, 08:28:02 PM
Last post August 16, 2011, 06:26:28 PM
by Roddy
Last post April 15, 2012, 08:52:07 AM
Last post November 22, 2013, 09:03:19 AM
Last post July 04, 2016, 11:35:16 AM
