Author Topic: 798 internal gps issues - out of nowhere  (Read 13183 times)
Offline alexpalmer1
  • Unit(s): 798c HS si
  • Software: 6.740
  • Accessories: i-ipilot link
« on: May 19, 2014, 10:56:28 PM »
Hi all.
I just got a 798, and everything was working great - updated to 6.740 (latest) and got my i-pilot link working.
On day #2 - the gps stopped working... it started with a 'lost gps signal' - and after a reboot says GPS UNCONNECTED in the accessory page.
I've tried power cycling many times - factory defaults - and even plugged in only the power connector at the bow of the boat, which was connected directly to the trolling batteries. Still no luck.
Any other ideas before I send it in? Sucks that it's a brand new unit, and already having problems.
Re: 798 internal gps issues - out of nowhere
« Reply #1 on: May 20, 2014, 10:48:37 AM »
Welcome to the Humminbird Side Imaging Forums alexpalmer1.
Sorry that your first post has to be about the GPS not working on your 798 unit.  Nothing that I can recommend you do except contact your local retailer about getting the unit fixed.  Maybe you can talk them into an external GPS Receiver to use instead of having to be without your unit.
Just curious: what software version are you running in your i-Pilot Link?
Offline alexpalmer1
  • Software: 6.740
« Reply #2 on: May 20, 2014, 11:35:08 AM »
i-pilot 1.16
Can the i-pilot link not share it's GPS via ethernet?
is there any connector inside the unit to the GPS? i.e. if I open it up, could the cable to the internal GPS just be loose?
« Reply #3 on: May 20, 2014, 12:54:20 PM »
alexpalmer1,
No, the i-Pilot Link does not share its GPS over the Ethernet connection.
I do not think that version of the 798 has a connector for the internal GPS as I believe it is built onto the PCB.  Opening the unit will void your warranty anyways.
Offline csapp
  • Unit(s): 798 sd side imaging
  • Software: latest
  • Accessories: none
« Reply #4 on: June 22, 2014, 06:24:53 PM »
I had this same issue, actually exchanged unit because I thouggt it was defective. Hooked up the new one and sametthing, I lost signal. I soldered all connections and cleaned battery cables and have not had anymore problems. It has been working like a charm ever since. 8)
If the hook ain't wet the fish ain't bitin!!!!
Offline alexpalmer1
  • Software: 6.740
« Reply #5 on: July 02, 2014, 01:32:59 PM »
Update:
After the unit was in for repair under warranty for 3 weeks, it's back and seems to be working properly. Not sure what they did, but hopefully it stays working.
Last post February 06, 2010, 11:13:18 AM
Last post September 09, 2011, 07:46:25 PM
by Jim Pauley
Last post December 04, 2010, 01:22:27 PM
by lcookie
by fishinphil
Last post April 30, 2013, 03:52:45 PM
Last post October 08, 2013, 07:42:13 PM
by SaminVa.
Last post May 09, 2014, 11:20:35 AM
Last post May 05, 2016, 09:00:18 AM
by Beaulieu80
