Author Topic: Internal GPS problems  (Read 8557 times)
Offline SaminVa.
  • Unit(s): 798ci SI HD
  • Software: 5.210
« on: October 06, 2013, 10:38:37 AM »
HI All, I have had my unit for a while now.
Was on the water yesterday using the gps... then all of a sudden it stopped.
Repowered up and did the self test and it showed disconnected or whatever the normal verbiage is when it doesn't show up.
 Have you all had any issues with this?
Any suggestions?
Thanks, Sam
Re: Internal GPS problems
« Reply #1 on: October 07, 2013, 10:40:00 AM »
Check the power connections to your unit.  Make sure that there is nothing loose or corroded and do not forget to check the fuse holder, fuse and battery connections.  Other than that you would either need to send it in to Humminbird to be fixed or install an external GPS Receiver.
Offline SaminVa.
  • Software: 5.210
« Reply #2 on: October 08, 2013, 07:42:13 PM »
Thanks for the help Greg.
I spoke with my local friend  Wayne Purdam and he suggested to gently and slighty spread the power connections pins.
I tired that and it worked ;D.
Thanks for the tips and I'm happy I don't have to send my unit in for repairs! :D
« Last Edit: October 08, 2013, 07:51:23 PM by SaminVa. »
Last post February 06, 2010, 11:13:18 AM
Last post September 09, 2011, 07:46:25 PM
by Jim Pauley
Last post December 04, 2010, 01:22:27 PM
by lcookie
Last post February 14, 2011, 09:52:42 PM
by weedsnager
Last post March 15, 2013, 11:53:28 AM
Last post April 30, 2013, 03:52:45 PM
Last post May 09, 2014, 11:20:35 AM
Last post May 05, 2016, 09:00:18 AM
by Beaulieu80
