Author Topic: 899ci SI poor DI image and shutting don on me!?  (Read 10939 times)
Offline Landry
  • Unit(s): 899
  • Software: 2
  • Accessories: Ethernet and HDSI SI ducer
« on: July 17, 2015, 12:07:45 PM »
I have a new 899ci SI that I have been running for a couple months. I have a couple bugs to fix though.
My SI images are great.
My down image sucks - not showing much really. I was thinking if I tilted the transducer downward that it might be better but I'd hate to mess with my SI Images.
Also my unit keeps shutting down on me while running in choppy water. My 859 does not do it and have good voltage readings. It happens when I hit a bump or wave. All connections have been tightened - anyone have this problem??
I am in Canada and also want to get the 800hz problem fixed - how do I get this done?
Landry
Re: 899ci SI poor DI image and shutting don on me!?
« Reply #1 on: July 17, 2015, 10:07:59 PM »
It is common for the DI images in the HB SI units to be "less than expected" ...
There is no "down pointing" piezo in the SI xducer ...therefore the DI image is a computer generated rendering from the data received in the "side pointing" SI piezoes ...
You can get somewhat better SI images by scanning known structure off to the side just a little ... This puts the structure closer to the "Main Axis" of one of the SI piezoes where it will reflect stronger echoes ...
Intermittent shutting off is usually attributed to a bad connection somewhere ... The cable collector, fuse holder, battery connection, etc ...
Try wiggling the cables at the back of the head unit and see if you can force replicate the issue ...
You might also try bending the pins in the power cable end just a tad to try and create more sideward resistance of the pins in the sockets ...
If you don't know the HB service center in your province of Canada ... You can call the main head quarters in Eufaula and they can tell you the steps you need to take to get your unit in to get the 800kHz washout issue fixed ...
1-800-633-1468
« Last Edit: July 17, 2015, 10:10:05 PM by rnvinc »
Offline Landry
  • Unit(s): 899
  • Software: 2
« Reply #2 on: July 31, 2015, 03:02:21 PM »
Fixed the shutting down problem I think:)
The Di looks great at times - mostly in shallow water but it's not great. Not why I bought it anyways.
Still happy with unit.
Last post August 20, 2010, 11:29:49 AM
Last post March 20, 2014, 03:40:17 AM
by bully
Last post July 28, 2014, 12:16:00 PM
by Kevin Kromrey
Last post June 04, 2014, 09:30:02 PM
by rpro
Last post April 25, 2015, 09:41:40 PM
by Hennessyt
Last post March 21, 2016, 04:38:52 PM
by moose5280
Last post June 19, 2019, 06:59:45 PM
by fshndude
Last post June 18, 2019, 08:09:35 PM
by snooktarpon
