Author Topic: 1199 Shutting off...  (Read 21347 times)
Offline Drowning Worms
  • Unit(s): 898C and 1199CI HD SI COMBO
  • Accessories: Ipilot link
« on: April 28, 2014, 09:37:53 AM »
I recently purchased a 1199CI HD SI COMBO to put in place of my 898.  First thing that I did was to update the software on the 1199, I had previously updated the software on my ipilot link with my 898.  When the 1199 is running by itself their are no problems but when I launch the trolling motor and just as  the 1199 is starting to recognize it the ipilot the 1199 shuts down.  What could be causing this?
Re: 1199 Shutting off...
« Reply #1 on: April 28, 2014, 02:47:08 PM »
Welcome to the Humminbird Side Imaging Forums Drowning Worms.
What software version are you running on your 199ci HD Si unit and do you remember what software version it was that you loaded on your i-Pilot Link and its remote?
« Reply #2 on: April 28, 2014, 07:42:51 PM »
Thanks Greg
The software version of the I pilot is 1.160 and the 1199 is 6.900
I just noticed that their other versions of the ipilot and controller but they are not available on my humminbird account only the two noted are.
« Last Edit: April 28, 2014, 07:49:08 PM by Drowning Worms »
« Reply #3 on: April 29, 2014, 01:57:35 PM »
Drowning Worms,
That’s the current software for the 1199 and i-Pilot Link.  Your controller should have software version 1.150 on it as well.  Not sure what is going on here.  Make sure all Ethernet connections are tight and if it still does it contact the Humminbird Customer resource folks.
« Reply #4 on: April 29, 2014, 05:46:21 PM »
Hey Greg
According to the Humminbird website if I am using version 6.900 or higher on my 1199 that I must use software version 2.020 for the remote and 2.050 for the controller.  How do I find these? and is this correct.
« Reply #5 on: April 30, 2014, 01:00:03 PM »
Doh!
Yep, with the 6.900 version (or higher) software you have to use a different file set.  Let me check on where you should be getting those from…
« Reply #6 on: April 30, 2014, 03:41:29 PM »
Drowning Worms,
The additional files should have showed up in your My Humminbird account but something is amiss with that site right now.  Send me a direct e-mail message with a request for the:
2.020.bin file for the i-Pilot Link Remote (6.900 software)
2.050.bin file for the i-Pilot Link Controller (6.900 software)
I’ll make sure that someone sends you a link back with where to download it from.
Offline gbishop
  • Unit(s): 1199,998,788
  • Accessories: ipilot
« Reply #7 on: April 30, 2014, 06:01:31 PM »
I need them to Greg , I've already called customer service & asked for the right downloads but there not showing up
« Reply #8 on: April 30, 2014, 08:36:58 PM »
Greg
Thanks for all your help on this matter.  I have sent you the email and look forward to getting the info and getting it loaded.
David
« Reply #9 on: May 01, 2014, 11:37:10 AM »
Replied to your message and sent the update files David.  You should have them by now...
gbishop,
I grabbed your e-mail address off the web site and sent the files your way too.
Offline gbishop
« Reply #10 on: May 02, 2014, 11:33:47 AM »
Thanks Greg,gonna update & try it this weekend. By the way,800 setting seemed just a little better after the 6.9 update,maybe on the right track.
« Reply #11 on: May 05, 2014, 08:16:58 AM »
Hey Greg
Just an update on the install of the new software.  Ill make it brief.  Tried to install but the install kept failing. Then the trolling motor lost all contact with the remote and the depthfinder.  I contacted Humminbird on Friday and am waiting to hear back from them.
DW
« Reply #12 on: May 08, 2014, 08:55:30 PM »
Still waiting for a reply from HB
« Reply #13 on: May 09, 2014, 10:11:50 AM »
DW,
Did you call Humminbird CRC or did you e-mail them?  I would give them a call back today.
Offline Bob Lammon
  • Unit(s): 898c hd si combo two units
  • Software: 7.?????
  • Accessories: GPS temp ipiolit
« Reply #14 on: July 26, 2014, 03:17:58 PM »
I am having the same problem with my 898c. I have two units that I updated and as soon as ipiolt  is connecting the unit shuts down... The down load was 7.00 something.?
« Reply #15 on: July 26, 2014, 07:04:34 PM »
Since I had the original problem on this thread I will let you know what happened (thought I already had).  The controller on my ipilot link got corrupted when the new software was being installed via the 1199.  MinnKota sent me a new controller and I installed it.  The units are working like a champ.  I would call the customer service desk at Humminbird and make them aware of this problem.  I also have a 898c that I have not reinstalled on the boat.  Maybe I will wait until I see what happens with yours.
DW
Offline Bob Lammon
  • Software: 7.?????
« Reply #16 on: July 27, 2014, 02:14:33 PM »
Thanks for the info. I cant get old software to load or I'm not downloading it properly
Offline Kevin Kromrey
  • Unit(s): 998/788HD/788HdDi/I-Pilot Link/Autochart
  • Software: always newest
  • Accessories: 5 port/nmea2k
« Reply #17 on: July 28, 2014, 12:16:00 PM »
I had same problem,  two 788 units one 998 with Link.  with latest updates installed on all units the 788s or 998 would shut down regularly.  I had to degrade the 998 software backwards....problem solved.  Would like to have latest software on 998/link/remote with autochart capabilities but cannot until 788 update comes out.  Hope this helps
Last post August 20, 2010, 11:29:49 AM
Last post October 19, 2012, 03:01:49 PM
by abuawaab
Last post March 20, 2014, 03:40:17 AM
by bully
Last post June 04, 2014, 09:30:02 PM
by rpro
Last post July 07, 2015, 07:52:53 PM
by yahoo
Last post July 31, 2015, 03:02:21 PM
by Landry
Last post April 17, 2017, 12:11:47 PM
Last post September 10, 2017, 08:47:57 PM
by baconstruction
