Author Topic: 899Ci problems with viewing Side Image  (Read 11628 times)
Offline moose5280
  • Unit(s): 899 ci hd si
« on: March 20, 2016, 09:56:33 AM »
Hello Friends,
I purchased a 899ci and installed it late 2015. had only a couple pf trips on it before the ice went on.  now ice is gone and I have managed a couple of trips out.  The problem is it seems there is a interference or something to cause the pictures not to be crisp or at time even view able.
The transducer is on a mobile mount (I have a small bass baby boat).
The transducer is about 1 foot below the water when I deploy to get under way.
I use a electric motor, but I get interference whether if motor is on or off.
The unit has never been able to produce those clear pictures I see from everyone else on the websites of their SI units.
Ive included a couple of pictures to show what i mean, any help would be appreciated.  Thanks
Offline moose5280
Re: 899Ci problems with viewing Side Image
« Reply #1 on: March 20, 2016, 09:57:57 AM »
Here is another one
Offline moose5280
« Reply #2 on: March 20, 2016, 09:59:24 AM »
One more
« Reply #3 on: March 20, 2016, 11:42:08 PM »
The white horizontal bands across the screen are usually indicative of TM interference ...
http://www.humminbird.com/Category/Support/FAQ/Trolling-Motor-Interference/
Try Restore Defaults under the setup tab to maybe get an errant setting back to default ...
If the issue persists you should call HB ... 1-800-633-1468
I would suggest have some screenshots available from the unit itself instead of third party software ... HB may want see them ...
Offline moose5280
« Reply #4 on: March 21, 2016, 04:38:52 PM »
Thanks rnvinc,
Ill give hummingbird a call and see what they can do!
Last post January 05, 2015, 05:05:03 PM
Last post April 25, 2015, 09:41:40 PM
by Hennessyt
Last post July 31, 2015, 03:02:21 PM
by Landry
Last post August 20, 2015, 12:54:42 AM
Last post March 13, 2016, 10:51:02 PM
by trogersIII
Last post May 13, 2016, 03:58:11 PM
by D S
Last post October 27, 2022, 08:39:37 PM
