Author Topic: 899ci Keeps Shutting Down on Start Up  (Read 14362 times)
Offline snooktarpon
  • Unit(s): 1199ci HD SI, 899ci HD SI
  • Accessories: AS-ETH-5PXG
« on: June 11, 2019, 08:51:42 AM »
I’m currently on a fishing trip and after one day of use my 899ci keeps shutting down right after I power it on and press the exit button. Basically when it power it on and I press the exit screen or go to the status screen, the unit shut down and reboots.
Here is a video shot by some else with the exact same issue:
I read on a previous post that someone fixed it by resetting the unit.
Since the unit shuts down before I can get to the menu, I don’t know how to reset the 899ci.
Please help ASAP since this issue will affect my fishing trip for the rest of the week.
Offline snooktarpon
Re: 899ci Keeps Shutting Down on Start Up
« Reply #1 on: June 11, 2019, 10:05:52 AM »
Quick follow-up:
-  i’ve been reading previous posts about this issue and it seems like this occurs on other the other series like the 1199, 999, etc.
- I have an 1199ci networked with my 899ci via the Ethernet switch all running off a new battery. The 1199ci works perfectly.
- From what I’ve read, it appears that there is a hardware issue and I have to send it in for service.
If anyone else has some further insight, I would appreciate it. Thank you!
Offline ezfishn
« Reply #2 on: June 11, 2019, 10:37:30 AM »
Did you fully charge battery after the 1st day?
Offline snooktarpon
« Reply #3 on: June 18, 2019, 05:37:25 PM »
Yes, my batteries gets fully charged each night. The battery charge state didn't change anything.
I'm going to call HB to send it in for repair.
Offline snooktarpon
« Reply #4 on: June 18, 2019, 08:10:11 PM »
I fixed it!
I called HB. I mentioned to them I wasn't running the lastest software (I'm using 7.590) since the current version (7.790) will not allow you deploy the Ulterra from the 899ci. So the HB support person told me to try to update the software to the current version. I forgot that you insert the SD card for the update right after you power the unit on and before you press the exit button. I thought you updated the software after the unit is up and running which I could get to with shut downs.
So I inserted the SD and it updated! After the update, the shutdown problem was gone! I then reverted back to the older software version and it still works.
So it appears that I had a corrupt software and updating it fixed it.
So if anyone has a unit with the shutdown issues, try updating (or downgrading if you are running the latest version) the unit.
Offline fshndude
« Reply #5 on: June 19, 2019, 06:59:45 PM »
Dude that is just great news. I will have to get my 899 back on the boat and see if it works for mine. Thanks so very much for the follow up.
Dave in Currituck,NC
Last post August 20, 2010, 11:29:49 AM
Last post October 19, 2012, 03:01:49 PM
by abuawaab
Last post March 20, 2014, 03:40:17 AM
by bully
Last post July 28, 2014, 12:16:00 PM
by Kevin Kromrey
Last post July 31, 2015, 03:02:21 PM
by Landry
Last post April 17, 2017, 12:11:47 PM
Last post April 01, 2018, 03:51:41 PM
by ezfishn
Last post June 18, 2019, 08:09:35 PM
by snooktarpon
