Author Topic: 998 Shutting Down  (Read 15436 times)
Offline fishesman
  • Unit(s): 998C
998 Shutting Down
« on: November 25, 2013, 11:51:24 AM »
I've had a lot of problems with my 998 shutting down lately. Whenever I press the "view" key and get to the "snapshot and recording"screen the unit will shutdown if I hesitate at all on this view. If I press the view key again quickly and proceed to the next screen I can usually keep it on. I have never used the screenshot function and I don't typically keep a card in the slot (I do have a Navionics card in one slot). This has been going on for a several months now (maybe since the last time I updated firmware- not positive).
This weekend I was out fishing and at the end of the day I scrolled over to my home port with the cursor and pressed the "goto" button. The unit shutdown as soon as I pressed the goto key. After I booted the unit back on I tried again with the same result and after several tries I gave up. I had used this function several times earlier in the day with no trouble.
Any ideas what's causing this?
Offline freezerfiller
  • Unit(s): 998c SI
  • Software: ??
  • Accessories: Ipilot link
Re: 998 Shutting Down
« Reply #1 on: November 26, 2013, 07:28:28 AM »
I'd run a separate fused power and ground straight to a known good battery first just to eliminate the possibility of it being a power supply/electrical issue.  I know mine would shut down when I would push a button when I tried to run it with a borderline power supply at the house.
Offline fishesman
  • Unit(s): 998C
« Reply #2 on: November 26, 2013, 09:15:02 AM »
Thanks for the advice. I was also thinking it might be a power issue.
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #3 on: November 26, 2013, 11:44:47 AM »
Make sure the power contact pins on the back of the unit are clean and good.  You can use a small slot screwdriver to carefully and slightly bend the pins to make solid contact.
Offline navionic
« Reply #4 on: November 26, 2013, 03:29:26 PM »
Clear history of navigation data. If there is important information -  save  in the program HumminbirdPC
Offline fishesman
  • Unit(s): 998C
« Reply #5 on: November 26, 2013, 04:01:32 PM »
Navionic - thanks for the suggestion. How does this fix my problem?
Offline LittleGazoo
  • Software: 3.640
« Reply #6 on: November 26, 2013, 04:06:41 PM »
I'd make sure the Navionics card is locked for write-protection.
You DO NOT want to accidently write to the Navionics card.
Offline navionic
« Reply #7 on: November 26, 2013, 04:15:13 PM »
Incorrect navigation data lead to the shutdown unit.
Offline bully
  • Unit(s): 997c
  • Software: 6.3
« Reply #8 on: March 20, 2014, 03:40:17 AM »
I had this problem with my 997.
In the end it was the new update I installed as corrupt, I downgraded the update to an earlier version then ran the update again - this solved the problem  ;)
Last post August 20, 2010, 11:29:49 AM
Last post October 19, 2012, 03:01:49 PM
by abuawaab
Last post July 28, 2014, 12:16:00 PM
by Kevin Kromrey
Last post June 04, 2014, 09:30:02 PM
by rpro
Last post July 07, 2015, 07:52:53 PM
by yahoo
Last post July 31, 2015, 03:02:21 PM
by Landry
Last post April 17, 2017, 12:11:47 PM
Last post September 10, 2017, 08:47:57 PM
by baconstruction
