Author Topic: 798c - temp reading crazy (150F)!  (Read 15137 times)
Offline lolar3288
  • Unit(s): 798ci
« on: July 13, 2015, 11:35:40 AM »
All of a sudden my temperature reading is crazy high...150 F and above.  Does this mean I have to replace the whole side scan transducer???
Larry
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: 798c - temp reading crazy (150F)!
« Reply #1 on: August 09, 2015, 09:27:42 PM »
Do you still have a temp problem? The post is almost a month old. I get reading like that when the stern is in the sun out of the water. Other than that situation I think your temperature probe is faulty. I would try to clean the connectors before I bought another HDSI though. Bob
Offline lolar3288
  • Unit(s): 798ci
« Reply #2 on: August 10, 2015, 08:58:39 AM »
Yep, still have the problem except now....no temp reading.  I guess the transducer is shot.  The unit is not that old in my opinion.
« Reply #3 on: August 10, 2015, 09:10:28 PM »
I'm pretty sure you could use the remote temp sensor on your 798 and then set the temp readout box to show this temp ...
http://www.humminbird.com/uploadedFiles/Content/Category/Support/FAQ/Accessory_resource-Guide_2014_X5.pdf
I would call HB to confirm ... 1-800-633-1468
Offline lolar3288
  • Unit(s): 798ci
« Reply #4 on: August 11, 2015, 08:17:35 AM »
Thanks for the reply. Problem is I own a fly bridge cruiser and the unit is on the fly bridge so it is a long and winding wire pull that required an extension.  No easy replacement job!  I was hoping it was a software issue!
« Reply #5 on: August 11, 2015, 09:19:37 AM »
Have you examined the transducer cable carefully to make sure there is no damage to it?
Last post June 24, 2012, 01:24:52 PM
by blackberg
Last post July 27, 2010, 12:04:04 PM
Last post January 19, 2011, 03:25:39 AM
by xSilmarilSx
Last post May 25, 2011, 11:14:10 AM
Last post May 01, 2012, 12:52:17 PM
by xSilmarilSx
Last post August 08, 2012, 11:20:17 AM
Last post April 30, 2014, 03:53:02 PM
by cdroke72
