Author Topic: HB 385 temp reading  (Read 8005 times)
fishbone
  • Guest
HB 385 temp reading
« on: January 18, 2011, 02:17:41 PM »
I plan to install a 385 on my kayak. A HB transducer kit will be used to mount inside the hull on the bottom. My question is 'how can the water temp be measured through the hull'?
Offline xSilmarilSx
  • Software: 6.250 - 5.320
Re: HB 385 temp reading
« Reply #1 on: January 19, 2011, 03:23:11 AM »
You won't have "water" temperature this way...but should be close.
I know that Humminbird sells an external Temp sensor: TG W
And from the Humminbird website, should be compatible with the 385
I have one on my 778c and it works perfect.
Offline xSilmarilSx
« Reply #2 on: January 19, 2011, 03:25:39 AM »
Oh, and for my setup on my kayak, I mount the transducer on the back as you would do on a transom, but with RAM Mounts parts. So I only left a small round attachment on the kayak and take off the transducer to use on my other boats.
So I have direct contact with water.
Send my your e-mail in PM and will send you a picture of my setup.
Last post June 24, 2012, 01:24:52 PM
by blackberg
Last post July 27, 2010, 12:04:04 PM
Last post April 19, 2011, 10:46:03 AM
by FuzzyGrub
Last post May 01, 2012, 12:52:17 PM
by xSilmarilSx
Last post August 11, 2015, 09:19:37 AM
Last post August 30, 2019, 12:43:39 AM
Last post December 18, 2020, 10:28:00 PM
