Author Topic: Thru Hull Transducer  (Read 9762 times)
Offline fishnnnn
  • Unit(s): 998
  • Software: 6.74
« on: May 23, 2015, 08:04:47 AM »
998c SI.
If you add a "Thru Hull" transducer, hook up y-cable to SI transducer, does the Thru Hull become the one that ALWAYS shows "Down Imaging, Switch Fire, RTS etc. No matter what boat speed?
Re: Thru Hull Transducer
« Reply #1 on: May 23, 2015, 03:32:21 PM »
The AS SIDB Y cable disconnects the 2d channel wire going to the 2d piezo in the XHS 9 HDSI 180 T ...
And re-routes the sonar signal to the "Dual Beam" xducer ...
With the AS SIDB Y cable ...:
*SI/DI and temp will always come from the XHS 9 HDSI 180 T ...
*2d will always come from the Dual Beam xducer ...
The settings in the unit do not change as this is merely re-routing wires ...so the unit will still see this setup as 1 xducer ...
Offline fishnnnn
  • Unit(s): 998
  • Software: 6.74
« Reply #2 on: May 23, 2015, 10:07:11 PM »
Thanks for info. So nothing I need to change anything in Settings?
« Reply #3 on: May 24, 2015, 12:18:02 PM »
Correct ...
The "Transducer Select" menu choice stays at "Hi Def Sidescan" ...
Last post April 24, 2013, 01:55:50 PM
by fishesman
Last post March 20, 2014, 12:49:02 PM
by Rotus623
Last post June 13, 2015, 06:53:07 PM
by bobcoy
Last post May 20, 2017, 08:31:51 AM
Last post April 01, 2018, 06:13:57 PM
by fishreed
Last post March 24, 2018, 08:59:08 AM
Last post July 16, 2018, 09:27:05 PM
Last post October 08, 2019, 08:22:14 AM
by danlaboucane
