Author Topic: Purchased boat has thru hull transducer...Questions  (Read 7223 times)
Offline JKWho
  • Unit(s): 798ci HD SI, 998c HD SI
  • Software: Up To Date
  • Accessories: NA
« on: June 13, 2015, 03:14:05 PM »
I recently purchased my first boat, as I do with all my toys I broke the boat down in order to get a feel for the entire situation I got myself into. I am running a 998 HD on the console and a 798 HD on the bow that are linked together. I was cleaning the battery compartment and found out I have a in  hull transducer with temp probe installed. I am wondering if it is worthwhile to hook it up to my 998 with a Y cable. Unfortunately I can get the boat on the water due to all the nearby lakes being closed (Texas, lots of rain). Is there a way to test it out of water to see if it even works? I understand these are used sometimes for high speed readings so I figure since it is already on the boat I might as well look into connecting it. Is there a way to tell which model transducer it is?
Any help would be awesome...
Thanks in advance
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Purchased boat has thru hull transducer...Questions
« Reply #1 on: June 13, 2015, 06:53:07 PM »
No way to check out of the water. There should be a label near the plug(12" or so from the plug. The "Y" connector will be between the transducer connection and the unit.It is about 12" long . Bob
Last post January 29, 2011, 04:48:39 PM
by GM
Last post March 11, 2011, 11:47:15 PM
by reddog
Last post May 15, 2012, 08:05:50 AM
Last post April 24, 2013, 01:55:50 PM
by fishesman
Last post July 10, 2013, 12:41:38 AM
by alanrmeadows
Last post March 20, 2014, 12:49:02 PM
by Rotus623
Last post May 08, 2015, 10:56:16 PM
Last post May 24, 2015, 12:18:02 PM
