Author Topic: Solix Thru Hull Transducer Angle  (Read 22444 times)
Offline nrgbentall
  • Unit(s): solix,997
« on: May 04, 2018, 02:30:43 AM »
Hi, looking for some advise,  below is a photo of the Solix xpth 14 20 msi T.
As the top edge and bottom edge of the transducer are not parallel to each other, can someone please advise which side should be used to set the transducer level to create the best image and object location.
Thanks in advance
Nick
Re: Solix Thru Hull Transducer Angle
« Reply #1 on: May 04, 2018, 09:52:57 PM »
Offline DennyO
  • Unit(s): Ulterra Link Solix 15 & 12 G2 5 pin Hub
  • Software: 3.40
  • Accessories: Softw2.14 L, 2.04R
« Reply #2 on: July 15, 2018, 04:44:28 PM »
I had an error on your page Rickie, maybe this was the page you were referring to? Section #3 on the first page deals with I believe his question. Seems to matter what the deadrise is above 2 or below in degrees? It looks like they are using the top surface to me.
https://humminbird.johnsonoutdoors.com/sites/johnsonoutdoors-store/files/product/hbtransducers/1093558/ProductManual/HUM_productmanual_IG_XPTH_SI_532551.pdf?_ga=2.45344228.1103714393.1531687117-1723663000.1531687117
« Last Edit: July 15, 2018, 04:50:14 PM by DennyO »
The Eyes have it! Hooking walleyes & watching Hawkeyes.
« Reply #3 on: July 16, 2018, 09:27:05 PM »
Yes your link is the link I was trying to use  ...
Seems that the block should be cut to allow the bottom face of the xducer to be parallel to the water's surface - thus posting the SI piezoes straight down  ...
Last post March 16, 2010, 04:53:21 PM
Last post March 16, 2010, 03:00:25 PM
Last post February 21, 2013, 08:56:17 AM
Last post May 14, 2013, 11:57:41 AM
by LittleGazoo
Last post May 02, 2014, 08:09:36 PM
by bobcoy
Last post March 04, 2015, 10:17:35 PM
Last post May 03, 2017, 07:11:16 AM
by N9Phil
Last post March 24, 2018, 08:59:08 AM
