Author Topic: How do I know when in-hull transducer is on?  (Read 10179 times)
Offline fishesman
  • Unit(s): 998C
« on: April 23, 2013, 11:58:34 PM »
I just installed a 998C SI on my 23' deep V center console. I also installed the Y cable and an in-hull puck transducer thinking I'd get better depth readings while on plane with this configuration. From what I've read, the 998C automatically switches to the in-hull transducer, but I don't understand what triggers it to switch from the SI transducer to the in-hull puck and back again? Also, is there a way to force the 998C to turn on the in-hull transducer so that I can test it out? Right now I have no idea when I'm using it and when I'm not. I have temporarily mounted the in-hull transducer inside a piece of pipe that is glued to the hull in the bilge. I filled the pipe with water and weighted the transducer down with a bag of sand. If I get good readings at the current location I'll epoxy it in place.
Thanks in advance for any insights.
Re: How do I know when in-hull transducer is on?
« Reply #1 on: April 24, 2013, 09:53:34 AM »
The actual configuration of the wire separation in the Y cable eliminates the wires going the 2d pins in the HDSI Xducer cable connector....
And directly configures the wires in the "other leg" of the Y cable to the in hull Xducer ...
So, in effect, the Y cable is physically disconnecting the 2d wires to the HDSI Xducer and replacing them with the 2d wires to the in hull Xducer...
If you have the Y cable installed and the unit is showing 2d returns...then it has no choice but to be returns from the in hull Xducer ...because the Y cable physically disconnected the wires going to the 2d crystal in the HDSI Xducer...
« Last Edit: April 24, 2013, 10:00:47 AM by rnvinc »
Offline fishesman
  • Unit(s): 998C
« Reply #2 on: April 24, 2013, 10:38:29 AM »
Thanks! That makes sense. For some reason I was under the impression that it switched back and forth depending on "something."
« Reply #3 on: April 24, 2013, 11:26:22 AM »
Nope, that would take a physical switch like the TS3 Transducer Switch, which the unit and AS-Si-DB-Y cable do not have built into them.
Nice way to test an inside-the-hull transducer.  Can you post pictures of this for others to see please?  Maybe under its own topic?  I’ve done this before and recommend it for deep V hulls.  T works well enough that a few have forgotten about the epoxy and just keep the tune filled with water…
Offline fishesman
  • Unit(s): 998C
« Reply #4 on: April 24, 2013, 01:55:50 PM »
Sure I'd be happy to. I just left on a fishing trip so it'll be a few days before I can post. Hopefully I'll have the new gear figured out when I get back.
Last post January 08, 2014, 02:54:18 PM
by hgv
Last post January 14, 2014, 02:47:55 PM
by Rotus623
Last post March 20, 2014, 12:49:02 PM
by Rotus623
Last post July 21, 2014, 04:13:30 PM
by TXAG DAC
Last post December 08, 2014, 12:36:47 PM
Last post February 20, 2015, 04:04:47 PM
Last post March 09, 2015, 04:10:44 PM
by TheSavant
Last post May 20, 2017, 08:31:51 AM
