Author Topic: Navigating to a waypoint from 899 does not work  (Read 14534 times)
Offline lorenzo42
  • Unit(s): 899ci si hd
« on: April 18, 2015, 04:56:13 PM »
Hello everyone,
I need some help. When I create a waypoint in the 899 ci hd si and then press the goto button, the terrova I pilot link does not go to the waypoint. It just sits there. Thoughts?
Thanks,
Laz
Re: Navigating to a waypoint from 899 does not work
« Reply #1 on: April 20, 2015, 09:10:56 AM »
Welcome to the Humminbird Side imaging Forums Laz.
Is the i-Pilot Link connected to the 899ci HD Si unit via an Ethernet connection?
Are you running the latest software version in the 899ci HD Si unit and the i-Pilot Link Controller and Remote?
Does the i-Pilot Link show as "CONNECTED" in the 899's Accessory Test View?
Offline Gimp
  • Unit(s): 998 HD SI
  • Accessories: i-Pilot Link
« Reply #2 on: April 20, 2015, 04:41:57 PM »
Is the Prop turned on?
Offline lorenzo42
« Reply #3 on: April 23, 2015, 08:28:57 PM »
YES
YES
YES
is the Prop turned on?
NO
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
« Reply #4 on: April 24, 2015, 07:35:08 AM »
I think there is a choice to have auto prop turned on or off. If you don't want to have to manually push the "PROP" button. Set auto prop to ON. Both in the remote and 899. Bob
Offline lorenzo42
« Reply #5 on: April 26, 2015, 12:46:55 PM »
Thanks guys. However, I was on the lake again today and I have Auto Prop ON and the terroava will still not automatically navigate to my waypoint. The waypoint(s) i am setting are at max. 50 ft away. The 899 is reading the i pilot link. What am I doing wrong?
Thanks in advance,
Laz.
Offline bobcoy
« Reply #6 on: April 26, 2015, 02:38:36 PM »
1 more question before you call CS. Is it the same result when you press go to on the remote?
Offline lorenzo42
« Reply #7 on: April 26, 2015, 04:08:59 PM »
The goto on the remote works great. I can set a spot-lock, save it, and I can recall it and the trolling motor goes there with no problems. It is just from the HB that it does not work. However, the software on the remote is V1.160 and (according to the remote). The controller software is:  V. 1.160.
Offline bobcoy
« Reply #8 on: April 26, 2015, 05:04:15 PM »
Then your "link" is not up to date! Need to update. Bob
Offline lorenzo42
« Reply #9 on: April 26, 2015, 06:10:19 PM »
Thanks Bob. I am going to give it  a go and see what happens. If this works, I will be a happy man! Thanks again.
Laz
Last post May 10, 2010, 09:10:33 AM
Last post July 24, 2011, 02:41:27 PM
by stillbear
Last post May 05, 2016, 07:18:24 PM
by Moose1am
Last post August 27, 2012, 02:58:59 PM
Last post June 18, 2013, 11:38:32 AM
by LittleGazoo
Last post January 30, 2014, 11:34:13 AM
by LittleGazoo
Last post December 27, 2014, 08:51:54 PM
by fishermanatr
Last post July 20, 2016, 01:11:09 AM
