Author Topic: Best "view" when navigating to waypoint...  (Read 12922 times)
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
  • Accessories: 998ci
« on: January 30, 2014, 08:26:00 AM »
With Humminbird I also use Garmin GPS 60 (hand GPS)...
This GPS has a view like a "compass". If I select some waypoint I can easily navigate to that point looking at compas arrow , Dist to Next  and compas "deviation" showing me if I'am to left or to right with my boat from course..
Which is the best "view" / "way" to use HB998 to navigate to some waypoint?  (with minimum accuracy)
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: Best "view" when navigating to waypoint...
« Reply #1 on: January 30, 2014, 11:34:13 AM »
Not something I do and others might be more helpful.
You could view the HB 998 full navigation map screen.
You should be able to use the GO TO ... and then select the Waypoint of your designation.
HB alarms can be adjusted for off-course alerts.
This would be more suitable for traveling to distant waypoints.
And it is "as the crow flies".  I don't think it would work well if the designation waypoint was on the other side of a large point of land.
« Last Edit: January 30, 2014, 11:35:42 AM by LittleGazoo »
Last post May 17, 2012, 12:42:44 PM
by RuffWood
Last post July 03, 2013, 12:02:11 PM
by Gattlin
Last post January 13, 2014, 01:28:47 PM
by hgv
Last post March 13, 2016, 10:41:49 PM
by Landry
