Author Topic: Waypoints when navigating  (Read 13734 times)
Offline fishermanatr
  • Unit(s): 898cHDsi Combo
  • Software: 7.090
  • Accessories: none
« on: December 21, 2014, 11:00:43 AM »
Is  there a way to show only the waypoint that you are navigating to on your nav screen?
We have many brushpiles in our waypoints, and they clutter the screen when navigating to a particular one.  The waypoint declutter does not clear the screen up enough.
It seems there should be a way to show only a particular waypoint, but I cannot seem to figure it out.
Tad
Offline brisner
  • BER Custom Lure Painting
  • Unit(s): Onix 10 ci SI, 1158 DI HD
  • Software: 2.0, 7.530
Re: Waypoints when navigating
« Reply #1 on: December 21, 2014, 02:11:45 PM »
Did you try the "Declutter" option?
  • Software: 7.090
  • Accessories: none
« Reply #2 on: December 21, 2014, 04:30:19 PM »
Yes, brisner, I did.  It made them smaller, but did not remove them from the nav screen.  Am I possibly doing something wrong?
Tad
« Reply #3 on: December 21, 2014, 10:37:31 PM »
« Last Edit: December 21, 2014, 10:38:59 PM by rnvinc »
  • Software: 7.090
  • Accessories: none
« Reply #4 on: December 22, 2014, 06:07:15 AM »
Thanks, Rickie.  Sorry I couldn't find it on my own!!
I am away from my boat until after New Years, so one more question.  If you show all waypoints to be not visible;  and you select "go to" on one waypoint, will it become visible automatically, or do you have to go back and change in waypoint management?
Thanks for taking your time to help me find something that I should have been able to do.   Merry Christmas to you, and all on this Forum.
Tad
« Reply #5 on: December 26, 2014, 09:46:05 PM »
So I did some experimenting ...
I powered on my unit in Normal ..and then shut off the sonar by pressing the Power button after full startup ... (This makes the unit a GPS chart plotter only)...
Then I formatted the Nav directories to clear out all waypoints ...
Then (after confirming my GPS antenna had found me) ...I opened a chart view and created 3 new waypoints north of my GPS position ...
Then I went into waypoint management under "Waypoints, Routes, Tracks" (under the Nav tab in the main menu system) .. And then made each of the 3 new waypoints "Hidden" ...(be sure to select "Save" before exiting)...
Then I exited out of waypoint management and opened a normal chart view... and then started a GOTO function toward "WP001"....
We can see that the GOTO function did, indeed start ... Indicated by the "Off Track" border and the "Target circle" around the "now Invisable WP001" ...(pay no attention to the course projection line because I was sitting still in my garage and the GPS doesn't know correct direction when not moving)...
So GOTO works with "Hidden" waypoints on the normal chart view ... But it doesn't make the chosen waypoint "visable"....
Now...interestingly ... (With the GOTO function still active on the normal chart view) ... I can go back into waypoint management, select the same waypoint (or any chosen waypoint from the list in the left pane)...and that single chosen waypoint (blue dot) will show in the upper right preview pane chart...
Furthermore ... I can zoom the preview pane chart with the (+,-) buttons on the unit face ...
This tells me that your desired option can be accomplished ... Sort of ...
*Make all waypoints "Hidden" in waypoint management ...
*Start a GOTO function in waypoint management or on the normal chart view ...
*Navigate the GOTO function toward the now "Invisable waypoint" on the normal chart view ...
*When you get close to the "Target circle" of the GOTO function on the normal chart view... Go into waypoint management, select the same waypoint from the list on the left ...and start zooming in on the preview pane chart as you get closer and closer to the waypoint (blue dot) ...
« Last Edit: December 26, 2014, 11:31:13 PM by rnvinc »
« Reply #6 on: December 27, 2014, 08:23:18 AM »
Rickie, thanks for all your work.  Chuck
« Reply #7 on: December 27, 2014, 10:17:32 AM »
I'm still learning also...
fishermanatr had a question I did not know the answer to ...so I was able to teach him and myself something...
« Last Edit: December 28, 2014, 09:44:21 PM by rnvinc »
  • Software: 7.090
  • Accessories: none
« Reply #8 on: December 27, 2014, 08:51:54 PM »
Thanks again, Rickie, for all of your work.  Can't wait to get back to my boat and try out what you have taught me!!
Happy New Year.
Tad
Last post May 10, 2010, 09:10:33 AM
Last post July 24, 2011, 02:41:27 PM
by stillbear
Last post May 05, 2016, 07:18:24 PM
by Moose1am
Last post August 27, 2012, 02:58:59 PM
Last post June 18, 2013, 11:38:32 AM
by LittleGazoo
Last post April 26, 2015, 06:10:19 PM
by lorenzo42
Last post July 20, 2016, 01:11:09 AM
