Author Topic: Need Help Navigating to a Waypoint  (Read 10635 times)
Offline slabbandit
« on: August 22, 2012, 10:56:23 PM »
 Learning to use a 998 HB. Any advice on the best way to navigate to a waypoint would be appreciated. What screen combinations are most popular to use when navigating? Just using base map right now, will get a lake map chip later.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
Re: Need Help Navigating to a Waypoint
« Reply #1 on: August 22, 2012, 11:05:15 PM »
Just set it to split between base map and 2d sonar. Set the map zoom to something you're comfortable with until you get a map card so you know what water depths you're working with.
Offline slabbandit
« Reply #2 on: August 22, 2012, 11:17:21 PM »
 I know the lake I fish very well and have seen it drawn down several times. If it makes any difference. Do you keep zooming as you get closer and what happens when the arrival alarm goes off. Does that mean you are over it or do you still need to navigate.
Offline LocDown
    • Fishing Videos
« Reply #3 on: August 23, 2012, 12:02:08 AM »
You can keep zooming as you get closer if you want, as for the arrival alarm, you set the distance or turn it off
« Reply #4 on: August 23, 2012, 04:33:58 PM »
The Arrival Alarm will sound when you are within the Arrival Alarm menu setting distance.  Once it sounds that unit will stop showing directions to that waypoint.  I prefer to use the Continuous Navigation Mode (set this menu to “On”).  It disables the Arrival Alarm but keeps giving you navigation data back to the waypoint; even if you pass it by.
Offline slabbandit
« Reply #5 on: August 23, 2012, 09:37:14 PM »
 Thanks Greg, I guess the arrival alarm is still set to factory default. I definately wan't to disable it. If you don't mind would you or someone run me thru the menu steps to do this.
   Thanks,
   Dave
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #6 on: August 23, 2012, 10:39:17 PM »
slabbandit
    Under the "Alarms" choice in the main menu, use the up/down arrow keys to get to "arrival".
    Factory default is 150'. Choices are---- Off to 3,000'.   Use left arrow key until --Off.
    Under the "Navigation" choice in the main menu, use up/down arrow keys to get to "continuous navigation mode".
    Factory default is Off.  Use right arrow key to On.
             Mike
« Reply #7 on: August 27, 2012, 02:58:59 PM »
slabbandit
             Mike
+1
Last post May 10, 2010, 09:10:33 AM
Last post July 24, 2011, 02:41:27 PM
by stillbear
Last post February 14, 2012, 06:43:07 AM
by stillbear
Last post May 05, 2016, 07:18:24 PM
by Moose1am
Last post June 18, 2013, 11:38:32 AM
by LittleGazoo
Last post December 27, 2014, 08:51:54 PM
by fishermanatr
Last post April 26, 2015, 06:10:19 PM
by lorenzo42
Last post July 20, 2016, 01:11:09 AM
