Author Topic: 899 turning off when cranking motor  (Read 9172 times)
Offline JoeyWelch
  • Unit(s): 899ci
« on: December 31, 2014, 05:57:46 PM »
I'm pretty sure it's dirty terminals but I'm wondering if there is any chance of this damaging the machine??
I love this machine.
Re: 899 turning off when cranking motor
« Reply #1 on: December 31, 2014, 10:05:33 PM »
The units are designed to shut off in a low power situation ...to prevent damage ...
Dirty terminals can be the issue ...
It could also be the battery is not in good enough condition to take the needed amps for cranking the big motor and run the electronics also ...
Load testing the battery is the best diagnosis for battery condition ...
« Last Edit: December 31, 2014, 10:08:18 PM by rnvinc »
Offline JoeyWelch
  • Unit(s): 899ci
« Reply #2 on: December 31, 2014, 11:14:01 PM »
Thanks Rickie. I'll have it load tested tomorrow.
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #3 on: January 01, 2015, 07:05:10 PM »
If it worked before and isn't now, I'd bet the battery is going fast.
I run really heavy wire to my units so I don't get any power sag to drop them out when I hit the key.....
G'Luck with it.
Offline Basspat66
  • Unit(s): 798ci
« Reply #4 on: January 02, 2015, 09:19:00 PM »
Low voltage on the battery.  Probably going bad or got a bad cell.  And yes, it will screw up the unit and/or GPS antenna.
« Reply #5 on: January 03, 2015, 12:12:11 PM »
Amperage distribution is all important. Think of it this way. A car needs a large amount of amps to start the engine. Even with a good battery when you press the start key notice how lights in the car seem to dim or even go out. that is the large draw needed to start. This is the same with starting a boat motor. It pulls a lot of current. For boats and sonar it is why the recommendation is to have two batteries. One for the motor and one for the sonar.  It is just the way that volts/current work.  So by all means make sure the supply is charged and has not gone low.... Chuck
Offline JoeyWelch
  • Unit(s): 899ci
« Reply #6 on: January 03, 2015, 12:27:10 PM »
I cleaned the connections and it seemed to fix the problem. Fished yesterday and it done fine. My battery has a purchase sticker on it from 5/06 so it's time to replace it regardless. Plan to get a new and higher cca battery this week. If for no other reason, just peace of mind. Thanks everyone.
Yesterdays crappie.
Offline sfw1960
« Reply #7 on: January 03, 2015, 07:50:39 PM »
Get the biggest you can afford & fit, enjoy the machine - it's a good one! >:D
Last post June 27, 2010, 03:56:34 PM
Last post December 09, 2010, 05:00:30 PM
by OleNørskov
Last post May 24, 2012, 07:40:30 AM
Last post August 03, 2012, 11:06:12 AM
Last post December 18, 2013, 03:22:53 PM
Last post July 07, 2015, 06:17:42 PM
by jessie33
Last post April 10, 2018, 09:59:05 PM
Last post July 31, 2020, 11:40:17 PM
