Author Topic: Turning off the FishID on Humminbird 570  (Read 8149 times)
Offline OleNørskov
  • Unit(s): 570
  • Accessories: speed and temperature
« on: December 09, 2010, 04:30:10 PM »
Hello everybody,
I just recently bought a Humminbird 570 and everybody tells me to turn off the FishID because it is not as accurate as the raw images you get when it is turned off.
I tried turning it off when using the simulator and it worked perfectly. I saw the "arches" that I was looking for. However, whenever I use it on the lake I don't see any arches at all.
What could be the problem?
Wayne P.
  • Guest
Re: Turning off the FishID on Humminbird 570
« Reply #1 on: December 09, 2010, 04:54:10 PM »
You have to be where fish are and you or the fish have to be moving for it to draw the arches.
This is a tutorial on the Lowrance web site about how sonar works and how it shows stuff. Check out the section about fish arches in the latter part of the tutorial. It may help you understand the process:
http://www.lowrance.com/en/Support/Tips-and-Tutorials/Sonar-Tutorial/
Remember that the arch shape has nothing to do with the shape of the fish, it is the way a subject passes thru the cone shaped sonar beam.
Here are some fish arches I saved on my Humminbird 798 when I was using it on the trolling motor:
« Last Edit: December 09, 2010, 05:47:12 PM by Wayne P. »
Offline OleNørskov
  • Unit(s): 570
« Reply #2 on: December 09, 2010, 05:00:30 PM »
Remember that the arch shape has nothing to do with the shape of the fish, it is the way a subjects passes thru the cone shaped sonar beam.
Thank you for the answer Wayne.
I tried to turn on the FishID and it showed a lot of fish but then I turned it off and there were non on the screen.
I will check out the link you sent me.
Last post June 27, 2010, 03:56:34 PM
Last post May 24, 2012, 07:40:30 AM
Last post August 03, 2012, 11:06:12 AM
Last post June 14, 2013, 10:35:25 AM
Last post July 26, 2013, 02:19:53 PM
by Gattlin
Last post December 18, 2013, 03:22:53 PM
Last post May 13, 2015, 03:45:34 PM
by MGEOD
Last post April 10, 2018, 09:59:05 PM
