Author Topic: gpss turning off  (Read 11636 times)
Offline goodwinexplorer
  • Software: 4.18
gpss turning off
« on: August 02, 2012, 05:57:33 AM »
hi i upgraded to the latest software on my 1197 csi unit after about 1 hour the gps stops working, if i turn the unit off and on, it resets fine, then 1 hour later the same problem.
i am recording the side scan to sd card at the time on a 15 mb/s ultra scandisk if i put a higher speed card 95 mb/s the system stops a 30mb/s the system jerks.
i did not have this problem last season is it the upgrade?
Re: gpss turning off
« Reply #1 on: August 02, 2012, 07:47:19 AM »
If you are not recording does it work ok?
We use a 2mb and record for 30 minutes and it is ok.
We are at the current software level..
  • Software: 4.18
« Reply #2 on: August 02, 2012, 12:48:01 PM »
i have not tried, i used a 2gb card and a 4 gb stop start the recordings every 20 minutes which i have been doing for 4 years and not had a problem.
« Reply #3 on: August 02, 2012, 12:57:50 PM »
I mistyped.  we are using the 2gb cards.  Without a problem.
Our code is the 6.3
Are you using waypoints on a card?
« Last Edit: August 02, 2012, 01:00:39 PM by sonar2000 »
« Reply #4 on: August 02, 2012, 01:01:43 PM »
Darn, I cant type today..
We are on release 6.310
I must need a pint of lagar and lime..
  • Software: 4.18
« Reply #5 on: August 02, 2012, 01:24:42 PM »
no i am using 6.180 i try the 6.3 and i am not using way points only recording the ss, i am using the gps to run a plotter via serial to usb converter as well
Offline Roddy
  • Scan,scan and rescan
« Reply #6 on: August 03, 2012, 01:00:29 AM »
Try updating  the unit 6.180 messed up a lot of units. The newest update fixed a lot of 6.180 problems.
Roddy
Scan,Scan and Rescan Roddy
« Reply #7 on: August 03, 2012, 09:34:34 AM »
I know I sound like a broken record, but I must say again:
Fully charge and load test your battery.
According to your post, your battery is a year older from last season.
Intermittant problems are often associated with the power supply.
  • Software: 4.18
« Reply #8 on: August 03, 2012, 09:46:08 AM »
12.8 is the reading on the unit the units dose not switch off just the gps stops working, going to try the new soft ware at the week end
« Reply #9 on: August 03, 2012, 11:06:12 AM »
12.8 only means your battery has adequate voltage.
It doesn't mean it can carry a load for any length of time.
Your voltage may be dipping down too low to run all of your
accessories, but still be enough to keep the unit on.
Also, check your power connections.
A small bump every once in a while could cause a lapse
in power.
Last post June 27, 2010, 03:56:34 PM
Last post December 09, 2010, 05:00:30 PM
by OleNørskov
Last post May 24, 2012, 07:40:30 AM
Last post June 14, 2013, 10:35:25 AM
Last post July 26, 2013, 02:19:53 PM
by Gattlin
Last post December 18, 2013, 03:22:53 PM
Last post May 13, 2015, 03:45:34 PM
by MGEOD
Last post April 10, 2018, 09:59:05 PM
