Author Topic: my new helix5si will not work in auto am i not turning it on correctly  (Read 7862 times)
Offline jessie33
  • Unit(s): helix5si
Have a new helix5si and have never been able to get a picture on it in auto mode. Works perfectly in ever other way just not in auto the screen is black when in auto. Am i not turning it on correctly at SI RANGE SCREEN? Does anyone else have this problem?
Try the Restore Defaults choice under the Setup tab ...
Then power off and power back on ...
During boot up watch the screen for a popup that says "Transducer not connected" ...
If you don't get that popup ... The unit should boot up to the NAV disclaimer screen ...
Press the "Exit" button at the NAV disclaimer screen to start Normal operation ...
Test on the water ... (Sonar doesn't work thru air) ...
« Last Edit: July 02, 2015, 05:17:24 PM by rnvinc »
Offline jessie33
  • Unit(s): helix5si
Thanks but sonar and all other features work perfect. No display after scrolling to auto in si range setting. Will work fine from one foot to 150 feet and beyond in man mode.
I'm not sure Jessie ...
It's supposed to work like this ...
http://youtu.be/597KhSMDcxE
Did you try the Restore Defaults ...??
Offline jessie33
  • Unit(s): helix5si
i did try defaults many times. i have now sent it to hummingbird service today hope they don't tell me there is nothing wrong with it.
Last post July 23, 2012, 07:15:10 PM
by jexeri
Last post July 06, 2013, 01:01:51 PM
by theflatlander
Last post August 20, 2013, 06:52:43 PM
by pingman
Last post March 25, 2014, 11:41:28 AM
Last post April 30, 2014, 03:08:02 PM
by tdclaymc16
Last post July 23, 2014, 07:39:48 AM
Last post May 12, 2015, 11:37:17 AM
by N9Phil
Last post May 26, 2016, 10:43:43 AM
by Bill H
