Author Topic: Helix 10 SI G1 turning itself on  (Read 9524 times)
Offline Tatersalad
  • Unit(s): helix 10 SI, 588 DI
« on: April 07, 2018, 11:46:03 AM »
I'm wondering if anyone has experienced this? My Helix 10 SI is usually on and in the start-up screen (the one that says press exit) when I remove the screen cover. I have been careful when putting on the cover so as to not push in the area of the on/off button and usually pull the top of the cover off to check that it is off before tarping my boat. The next time I remove the cover it is turned on.
I have it connected direct to the starting battery and the battery has a single bank Minn Kota onboard charger connected and plugged in while in storage. Battery is always fully charged. Boat is tarped and under carport when not in use.
Right now I have it with the bottom right corner of  cover not fully pressed on. I'll have to check it when it warms up a little.
Any one with any ideas or similar experiences.
Tater
Offline ezfishn
Re: Helix 10 SI G1 turning itself on
« Reply #1 on: April 07, 2018, 01:15:26 PM »
I've only seen it a couple of times because of the cover.  If the issue is only happening during storage then maybe a battery cutoff switch to isolate battery from the boat during charging.  I have a cutoff switch for both the cranking and TM batteries so now I never put the cover on until I know the cut-off switch is turned off.  Haven't seen any corrective measures for the cover but maybe someone else knows a different cure.
Offline D Johnson
  • Unit(s): 2 networked Helix 10 Chirp SI GPS G2N
  • Software: 1.610
  • Accessories: B1gF1sh@HB
« Reply #2 on: April 07, 2018, 05:24:15 PM »
All my electronics are on a dedicated battery in my console.  Positive on the battery goes to a breaker on the dash then to a switch beside the breaker then to the buss bar.  I kill all power going to all electronics at the end of a day fishing as soon as the boat is on the trailed.  I too have had mine turn on when putting the cover on. Don
Don
Offline bobxxx
  • Unit(s): hb798cihd,hb helix9 si di mega,helix7 si
  • Software: 6.61,1.160,1.84
  • Accessories: AS GPS HS
« Reply #3 on: April 08, 2018, 11:34:48 AM »
Had same problem.
installed a on off battery switch.
Bob
Offline Tatersalad
« Reply #4 on: April 08, 2018, 04:40:09 PM »
Thanks for the replies, now I know I'm not alone having this happen. I'll get it taken care of.
Tater
« Reply #5 on: April 08, 2018, 11:25:25 PM »
I have modified the rubber cover by gluing a rubber O-ring around the area (inside the cover) that touches the power button  ...
This created a bumper (of sorts) around the power button to keep the rubber cover from pressing against the power button  ...
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #6 on: April 09, 2018, 11:35:36 PM »
      That is a clever, simple and effective solution.  What type of glue did you use for the rubber/plastic bond?
             Mike
« Reply #7 on: April 10, 2018, 09:52:48 PM »
             Mike
Goop Marine adhesive  ...
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #8 on: April 10, 2018, 09:59:05 PM »
      thanks
      Mike
Last post June 27, 2010, 03:56:34 PM
Last post December 09, 2010, 05:00:30 PM
by OleNørskov
Last post May 24, 2012, 07:40:30 AM
Last post August 03, 2012, 11:06:12 AM
Last post June 14, 2013, 10:35:25 AM
Last post December 18, 2013, 03:22:53 PM
Last post January 03, 2015, 07:50:39 PM
Last post July 31, 2020, 11:40:17 PM
