Author Topic: NMEA  (Read 10180 times)
Offline ldbrw1
  • Unit(s): 998c SI
  • Software: not sure yet
  • Accessories: none yet
NMEA
« on: December 19, 2013, 09:29:47 AM »
I have a new 998c SI still in the box waiting for my boat build completion.  I will be getting a Yamaha 115 HP 4 stroke.  I would like to hook up NMEA so I can see engine readings on my 998.  What do I need besides a NMEA2K Adapter to do this?  The HB website says something about a NNEA2000 backbone.  Does the engine have this or do I need other parts and where might I find these?
Thanks for any help.
Re: NMEA
« Reply #1 on: December 19, 2013, 02:04:42 PM »
All I can tell you is from the Humminbird end of things.  You will need the AS-ETH-NMEA2K NMEA 2000 Adapter.  I recommend you download the operations manual and review what else is needed (like the NMEA 200 backbone).
http://store.humminbird.com/products/629938/NMEA2K_Adapter
Humminbird does not sell the NMEA 2000 backbone parts.
http://store.humminbird.com/media/document/NMEA2000ModuleInstallationandOperationsManual.pdf
Offline wpda
Re: NMEA
« Reply #2 on: December 19, 2013, 09:00:17 PM »
i've done a few of these now
you will need to build an nmea backbone and power it if 1 does not already exist
you will also require a gateway or adaptor from Yamaha to get their nmea signal into the backbone
Offline alex_croatia
    • www.maris.hr
  • Unit(s): 998c si
  • Software: 6.740
  • Accessories: 998c si
Re: NMEA
« Reply #3 on: December 21, 2013, 11:44:32 AM »
I wont the same , I have 998c SI and new Suzuki 115 HP 4 stroke  I would like to hook up NMEA . what connections I need ?
Re: NMEA
« Reply #4 on: December 26, 2013, 01:52:33 PM »
I would think that you would need the same (AS-ETH-NMEA2K NMEA 2000 Adapter, NMEA 2000 backbone and a connection/adapter cable from Suzuki to connect it to the NMEA 2000 backbone).
Offline ldbrw1
  • Unit(s): 998c SI
Re: NMEA
« Reply #5 on: December 26, 2013, 08:45:34 PM »
Checked with my dealer and I would need to have the Yamaha Command Link package upgrade plus the HBird part and another part.  Over $1000 so I guess I will pass on this for now.
Last post May 04, 2011, 04:17:29 AM
by SonarTRX
Last post May 24, 2011, 03:04:20 PM
nmea ?
Started by T.G 898c SI
Last post November 27, 2012, 01:38:42 PM
Last post August 16, 2012, 03:01:49 PM
Last post August 16, 2012, 04:03:35 PM
Last post February 27, 2014, 10:54:48 PM
by freezerfiller
Last post May 05, 2014, 07:50:53 AM
by NJsquatch
Last post June 29, 2014, 06:36:37 PM
by jjmoney
