Author Topic: NMEA, I'm confused  (Read 13695 times)
Offline freezerfiller
  • Unit(s): 998c SI
  • Software: ??
  • Accessories: Ipilot link
NMEA, I'm confused
« on: February 20, 2014, 08:23:12 AM »
A few months ago, I wanted to get a fuel flow sensor for my boat that had a pre - NMEA 2000 engine on it.  I thought rather than buy a gauge and drill another hole in the dash,  it would be better to buy a NMEA fuel flow sensor and plug it up to the 998c SI.  I then fired it up in simulation mode and found that fuel flow/burn rate was not an option for my display outputs..  So I posted about it in the wish list section and moved on with my life, not doing anything.   Then I come across this thread:  http://forums.sideimagingsoft.com/index.php?topic=6756.msg40176#msg40176
So now I'm back to wondering..  If I get a NMEA backbone with a fuel flow sensor, will the unit see it and give me the option to display that if I'm not in simulation mode?
  • Unit(s): 998c SI
  • Software: ??
Re: NMEA, I'm confused
« Reply #1 on: February 26, 2014, 05:06:39 PM »
Don't everybody jump in at once....
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #2 on: February 26, 2014, 05:34:05 PM »
I'd be glad to try to help you, but I know nothing about NMEA, so your better off without my "help".
Have you tried sending a PM to either of the guys working on the problem?  They have a lot of time and effort in it.
Offline wpda
« Reply #3 on: February 26, 2014, 06:24:51 PM »
YES IT WILL WORK AS LONG AS THE INSTANCE IS RECOGNIZED AND DOES NOT CLASH AND IF THE PGN IS ALSO CORRECT
  • Unit(s): 998c SI
  • Software: ??
« Reply #4 on: February 27, 2014, 10:53:51 PM »
I did send a pm to Viper.  He responded, but he has an advanced (modern) engine that has the NMEA built in.  Sounds like it may work, but I'm not in the "gamble $500 to see if it works" club.
  • Unit(s): 998c SI
  • Software: ??
« Reply #5 on: February 27, 2014, 10:54:48 PM »
This sounds promising.  What is a PGN?
Last post April 01, 2010, 07:51:27 AM
Last post November 21, 2010, 07:35:00 PM
by littleman
Last post May 02, 2012, 08:32:48 AM
Last post June 14, 2012, 12:12:15 PM
Last post June 12, 2013, 01:17:35 PM
Last post March 17, 2014, 09:00:37 AM
by PeekRhol
Last post July 20, 2016, 01:11:09 AM
Last post January 30, 2020, 09:36:16 PM
