Author Topic: NMEA  (Read 8428 times)
Offline cloudman
  • Capt
  • Salt water fishing for Marlin
  • Unit(s): 1197c si
  • Software: 4.95
  • Accessories: nil
NMEA
« on: August 07, 2012, 10:11:41 PM »
Can a 1197c Si be linked to a Simrad NSS12?
Re: NMEA
« Reply #1 on: August 08, 2012, 03:29:04 PM »
What do you mean by “linked”?
The NMEA 0183 data output of the external GPS Receiver and/or unit can be sent to a second device.  I don’t know if the Simrad NSS12 can use this data or not.  Look in your operations manual for that product.
Offline cloudman
  • Capt
  • Unit(s): 1197c si
  • Software: 4.95
  • Accessories: nil
Re: NMEA
« Reply #2 on: August 11, 2012, 08:12:45 PM »
Linked as in connected to a network NMEA 2000, what data does the 1197C si transmit over the NMEA 0183
Re: NMEA
« Reply #3 on: August 16, 2012, 03:01:49 PM »
Yes, the 1197c Si is able to be connected to an NMEA 200 system using the AS-ETH-NMEA2K accessory.
The NMEA 0183 data sentences that the 1197c Si outputs is:
GLL - Geographic Position - Lat/Lon
GGA - GPS Fix Data
RMC - Recommended Minimum Specific GNSS Data
VTG - Course Over Ground and Ground Speed
ZDA - Time and Date
APB - Autopilot Sentence B
BWR - Bearing & Distance to Waypoint - Rhumb Line
RMB - Recommended Minimum Navigation Information
DPT - Depth
MTW - Water Temperature
Last post June 21, 2010, 11:39:18 AM
Last post September 20, 2011, 08:48:00 AM
Last post May 04, 2011, 04:17:29 AM
by SonarTRX
Last post May 24, 2011, 03:04:20 PM
Last post September 12, 2011, 06:17:29 PM
Last post April 10, 2012, 07:38:45 PM
nmea ?
Started by T.G 898c SI
Last post November 27, 2012, 01:38:42 PM
Last post August 16, 2012, 04:03:35 PM
