Author Topic: nmea in ?  (Read 18121 times)
Offline leeloo
  • My boat
  • Unit(s): 981
nmea in ?
« on: May 15, 2011, 03:43:40 PM »
981 nmea in ??from plotter ?cable red,yello.white .black?I nead gps signal.Sorry f the spelling.
Re: nmea in ?
« Reply #1 on: May 15, 2011, 04:04:38 PM »
The white wire should be the nema xmit to the next device.
 Green Rec
 White Xmit
 Red + 12V
 Drain or Ground
Offline Rüdiger
Re: nmea in ?
« Reply #2 on: May 16, 2011, 03:10:03 AM »
Hey leeloo  :)
The manual give´s only information's about NMEA-out, so i think HB support not NMEA-in.
mvh
Rüdiger
Finding is better than losing
Re: nmea in ?
« Reply #3 on: May 16, 2011, 03:22:32 PM »
Rudiger is correct: NMEA Output only.  No NMEA Input.
You should be able to take the NMEA output off of the NMEA pigtail wire.  This is the shorter cable that comes out of the GPS Receiver’s cable connector.  Take the black plastic cap off and you should have a Red, White and Black wire.  Terminate the Red wire so it does not make an electrical connection to anything else.  The White wire is the NMEA Output (NMEA +) and the Black wire is the NMEA Ground (NMEA -).  Set the NMEA Output menu to “On” and you should be ready.
Offline leeloo
  • My boat
  • Unit(s): 981
Re: nmea in ?
« Reply #4 on: May 23, 2011, 12:40:54 PM »
i put together greencable 981, and white from plotter and black to black.Now i have gps data in my 981.is it not nmea in to 981.Using the nmea com cable.
Offline leeloo
  • My boat
  • Unit(s): 981
Re: nmea in ?
« Reply #5 on: May 23, 2011, 12:45:08 PM »
ps My plotter is furuno.
Re: nmea in ?
« Reply #6 on: May 24, 2011, 03:04:20 PM »
Think I understand now: you are using the NMEA Output from your Furuno to go to the 981c Si unit.  Yes, that would be NMEA In to the 981 unit.  Sounds like you are using the AS-HHGPS cable for this as well.  Sorry, thought you were trying something else.
Last post May 04, 2011, 04:17:29 AM
by SonarTRX
Last post August 12, 2011, 02:08:51 PM
Last post September 12, 2011, 06:17:29 PM
Last post February 03, 2012, 04:24:23 PM
Last post April 11, 2012, 10:22:08 AM
Last post February 27, 2012, 12:27:36 AM
by depark1
Last post April 10, 2012, 07:38:45 PM
Last post July 21, 2012, 10:46:47 AM
by erocks4u
