Author Topic: nmea  (Read 12841 times)
Offline Coen Onstwedder
    • Northseadivers
  • Unit(s): Helix 12
  • Software: 2018
nmea
« on: May 04, 2011, 03:50:17 AM »
can somebody tel how i can work with the 1197 an a computer with Dr.Depth because its not working, NMEA is on.????????
Offline Rüdiger
Re: nmea
« Reply #1 on: May 04, 2011, 04:09:33 AM »
Hey Coen Onnstwedder  :)
What Windows-version do you use ?
If you use a RS232-USB converter look in the systemcontrol-settings-machinsettings-com ports and you can see what port the converter use.
Than look in the settings of DrDepth, as you use the same port.
mvh
Rüdiger
Finding is better than losing
Offline SonarTRX
    • SonarTRX
  • Unit(s): 998c-SI
  • Software: SonarTRX
Re: nmea
« Reply #2 on: May 04, 2011, 04:17:29 AM »
Quote
A couple of additional things to check:
Have you validated that the serial data is actually arriving on the serial port of the computer (using Hyperterminal etc.), and also that the Baud rate and other port-settings match what is expected?
Many serial port drivers and USB-to-Serial devices also have problems if there is "live" data on the port when you start the computer. There are however some registry work-arounds, but it is probably not the problem you are having.
Best Regards,
Tore
tore@sonartrx.com
www.sonartrx.com
Last post May 24, 2011, 03:04:20 PM
Last post August 12, 2011, 02:08:51 PM
Last post September 12, 2011, 06:17:29 PM
Last post February 03, 2012, 04:24:23 PM
Last post April 11, 2012, 10:22:08 AM
Last post February 27, 2012, 12:27:36 AM
by depark1
Last post April 10, 2012, 07:38:45 PM
Last post July 21, 2012, 10:46:47 AM
by erocks4u
