Author Topic: Well I took the plunge into nmea  (Read 8187 times)
Offline thunderbucket
  • Unit(s): 898cxsi
  • Software: 5.4
  • Accessories: GR50 and a non-working base map
« on: April 01, 2013, 11:43:20 AM »
Started rigging my boat this weekend and since I am only running the one 898 I don't need the Ethernet port hub, just the nmea2k adapter... All is  good except when I took the nmea2k adapter out of the package and realized the cable is only two feet long.
I haven't seen a male to female cable on the humminbird site to extend the length to reach my 898 mounted on my console,  can anyone point me in the direction of a cable supplier, or has anyone have any experience with this 8)
« Last Edit: April 01, 2013, 12:40:03 PM by thunderbucket »
Re: Well I took the plunge into nmea
« Reply #1 on: April 01, 2013, 02:33:45 PM »
You mean the AS-ECX-30E Ethernet Extension Cable?
http://store.humminbird.com/products/629937/AS_ECX_30E
  • Unit(s): 898cxsi
  • Software: 5.4
« Reply #2 on: April 01, 2013, 04:24:58 PM »
Nope I need a extension cable with one male end and one female end
« Last Edit: April 01, 2013, 04:31:25 PM by thunderbucket »
« Reply #3 on: April 02, 2013, 09:41:57 AM »
That is what the AS-ECX-30E is:
AS ECX 30EAccessories760025-1.Ethernet Extension Cable
The Ethernet Extension Cable is a 30' cable that allows you to extend the length of your ethernet cables.
  • Unit(s): 898cxsi
  • Software: 5.4
« Reply #4 on: April 02, 2013, 10:10:16 PM »
Thanks or the PDF file... Funny thing is on the humminbird website it shows cables with both ends the same
30' is going to be overkill... Do they have a shorter cable with a male and female end?
« Last Edit: April 02, 2013, 10:21:26 PM by thunderbucket »
« Reply #5 on: April 03, 2013, 08:02:23 AM »
No, that is the only Ethernet extension cable that we have.
  • Unit(s): 898cxsi
  • Software: 5.4
« Reply #6 on: April 03, 2013, 10:39:40 PM »
Nuts just my luck
Last post May 04, 2011, 04:17:29 AM
by SonarTRX
Last post May 24, 2011, 03:04:20 PM
nmea ?
Started by T.G 898c SI
Last post November 27, 2012, 01:38:42 PM
Last post August 16, 2012, 03:01:49 PM
Last post August 16, 2012, 04:03:35 PM
Last post May 22, 2013, 01:36:53 PM
by promapper
Last post December 26, 2013, 08:45:34 PM
by ldbrw1
Last post February 11, 2014, 10:42:17 AM
