Author Topic: Tansducer placement for SI.  (Read 5630 times)
Offline kenrose
  • Unit(s): Matrix 55
« on: March 02, 2012, 07:52:31 AM »
I am purchasing a 798 ci HD SI. Is it true that the side imaging only works when the boat is not on plane? If so, I assume this is because the placement of the transducer on the transom causes the sides of it to be out of the water when planing..If this is the case, would it be possible to place the transducer on the bottom of the boat, at the aft end of the keel, so it will always be submerged even on plane and have unobstructed side to side view?
Offline George
  • Software: Always up todate
Re: Tansducer placement for SI.
« Reply #1 on: March 02, 2012, 08:12:47 AM »
kenrose
To get Side and Down Imaging you have to be around 5 mph or less, sometimes you can go a little faster but not much.  It is not a matter of being on plane, speed is the issues which causes turbulence.
Doug Vahrenberg has a 9 video seminar to help you get the most out of Side Imaging, it is worth a look.
--->  http://www.dougvahrenberg.com/Videos.html  <---
George
« Reply #2 on: March 02, 2012, 10:40:49 AM »
It is not that Si sonar won’t work at higher boats speeds: above about 5 -6 mph the units cannot show the detail in the Si sonar that they can at slower speeds.  So while Si sonar is capable of being used at higher boat speeds: they just do not show the same level of detail that is possible at lower boat speeds.
On those boats that cannot get Si sonar to work at the higher boat speeds it is due to the placement of the transducer.  Note: Not all boat hulls allow for the placement of an Si transducer that will allow for both good high-speed 2D and Si sonar readings.  Your boat may or it may not.
« Reply #3 on: March 02, 2012, 10:46:37 AM »
How does chart speed relate to boat speed?
How does ping speed relate to boat speed?
How does all of this effect the display?
Especially the length of a target.
chuck
Last post February 26, 2010, 12:00:42 PM
Last post April 09, 2010, 11:19:49 AM
Last post June 20, 2010, 07:38:02 AM
by IRC Kevin
Last post September 08, 2011, 09:45:43 PM
by HarrisonDawgs
Last post September 16, 2011, 09:55:49 AM
Last post January 09, 2012, 08:35:19 AM
Last post January 17, 2012, 06:43:41 PM
by Singleshot
Last post March 07, 2012, 07:01:54 PM
