Author Topic: SI transducer placement  (Read 10509 times)
Offline redheelerdog
  • Unit(s): 997c SI
« on: June 19, 2010, 12:35:34 AM »
Hi,
Question on SI transducer placement –
Do most of you place your transducer below the bottom of the boat?
I have an 898C SI on order and I was reading the “Transducer Breakage” thread here.
Got me thinking about transducer location, I currently have an old Lowrance unit that is mounted about 1” below the back and bottom of the boat – I have had this transducer kick up numerous times from hitting small objects floating in the water.
If I put the SI unit just even with the bottom of the boat I think it would still give a good signal, I could still use my old Lowrance unit like it is now and maybe avoid damage to my new SI ducer.
My boat is an 18’ aluminum Hewescraft semi-V, 150HP outboard jet, mostly used in rivers.
Just wanting some feedback on others SI transducer placement.
TIA
-redheelerdog
Montana
Re: SI transducer placement
« Reply #1 on: June 19, 2010, 12:41:17 AM »
The SI Transducer will need to sit down in the water below the hull line.  There are quite a few Installation images in the Image Gallery.
When you install it, you would want to have the horizontal centerline of the transdcuer line up with the bottom of the hull line.  Then you can adjust it up or down as needed.
Hope that helps and good luck,
IRC Kevin
  • Guest
« Reply #2 on: June 20, 2010, 07:38:02 AM »
Where I cruise, there is quite a lot of waterlogged debris that doesn't quite float. Having just had to have my prop reprofiled after hitting some unknown object, I'm very glad that my transducers are mostly protected by the transom.
Last post April 09, 2010, 11:19:49 AM
Last post September 16, 2011, 09:55:49 AM
Last post February 02, 2012, 10:25:51 AM
Last post November 25, 2012, 12:41:58 PM
by Speedtroller
Last post March 07, 2012, 07:01:54 PM
Last post April 03, 2012, 09:47:31 AM
Last post April 06, 2012, 04:29:55 PM
by Brian37075
