Author Topic: Will this tranducer placement work?  (Read 7845 times)
Offline kilrbil
  • Unit(s): 898c SI
« on: December 31, 2011, 09:18:09 PM »
I am new here and have been reading so much but still not sure if this is the right place to put the transducer. I've attached a photo and was wondering if I place it where my old transducer is if it would be the best place. ila_rendered" alt="" class="bbc_img" />
Offline George
  • Software: Always up todate
Re: Will this tranducer placement work?
« Reply #1 on: January 01, 2012, 08:44:49 AM »
kilrbil
Your transducer appears to be clear on both sides, the only question is when the Outboard is down does it get in the way of the transducer.  It looks like you will be ok, I would not change anything until it is tested on the water.
George
« Last Edit: January 09, 2012, 12:03:56 PM by George »
« Reply #2 on: January 04, 2012, 11:50:48 AM »
kilrbil,
Hard to say from just the one photo but I agree with George in that it does look like it might work when mounted there.  Can you post some additional pictures of the overall transom area of your boat?  They need to be from a lower height so that we can see things at the same level that the transducer will be at.  Are you trying to use the one transducer for both Si sonar and high-speed 2D sonar readings?
Offline kilrbil
  • Unit(s): 898c SI
« Reply #3 on: January 08, 2012, 09:08:53 PM »
 I appreciate the help...I don't know if this picture is any better but it's the only other one I hadila_rendered
« Reply #4 on: January 09, 2012, 08:35:19 AM »
Kilr...That looks like a Lowrance transducer.  (200 skimmer)  For that transducer it should have worked fine.
Depending on the HB transducer you might plan on having the ducer a bit higher.
Also you might check some of the pictures in the gallery as the HDSI is a bit sensitive to placement.
Last post February 26, 2010, 12:00:42 PM
Last post April 09, 2010, 11:19:49 AM
Last post June 20, 2010, 07:38:02 AM
by IRC Kevin
Last post December 21, 2011, 12:50:39 PM
by Double Digit
Last post November 10, 2010, 12:46:43 PM
Last post September 16, 2011, 09:55:49 AM
Last post January 17, 2012, 06:43:41 PM
by Singleshot
Last post February 02, 2012, 10:25:51 AM
