Author Topic: Transducer Placement on Fiberglass Lund.  (Read 11790 times)
Offline DiemakerDave
  • Unit(s): 898c SI
  • Software: 6.180
« on: March 06, 2012, 08:31:22 PM »
Greetings All,
1st. post here and hopefully not beating a dead horse too much.
After going through all the installation pictures I found on here and reading all the search results, I still have questions.  :-\
The transducers on the boat will be coming off or will be relocated higher. I think they're 200 kHz, one is a Wide 100 and the other is a flasher. The back of our boat has steps up along the "V", which I haven't seen too many installation pictures of.
The transducer that came with the boat, on the right side picks up at speed half of the time right now. Haven't really played with it since it was getting replaced. I don't think I want to mount the new one there, seems a little bit too close to the turbulence from the prop.
I'm thinking of installing the transducer in one of 2 places, either before the step (1) or after (2) in the picture or should I go to the closer step? Not quite sure which side of the step I should be on.
Hopefully it won't pick up the motor while it's down. The motor is down in the picture where it normally is, but the transducer is a little bit longer then the gap between where the boat plug goes and the motor.
Dave
Offline xSilmarilSx
  • Software: 6.250 - 5.320
Re: Transducer Placement on Fiberglass Lund.
« Reply #1 on: March 07, 2012, 06:19:11 AM »
Normally, on Fiberglass boats, you mount the transducer inside the hull, in the bilge..
Just do a test before glueing it down since some fiberglass setup might not work
Offline RECONER
  • TRITON 22 LTS
« Reply #2 on: March 07, 2012, 06:49:28 PM »
I learn something everyday so would there be a difference inside versus outside. :)
« Reply #3 on: March 07, 2012, 07:01:54 PM »
What model unit do you have.....SI is usually mounted on the transom and sometimes a 2D transducer is mounted inside the hull for high speed 2D readings.  Inside the hull depends on the kind of fiberglass for the 2D.
Last post April 09, 2010, 11:19:49 AM
Last post June 20, 2010, 07:38:02 AM
by IRC Kevin
Last post September 16, 2011, 09:55:49 AM
Last post February 02, 2012, 10:25:51 AM
Last post November 25, 2012, 12:41:58 PM
by Speedtroller
Last post May 23, 2012, 01:06:26 PM
by Brian37075
Last post March 24, 2013, 07:54:30 AM
by short grub
