Author Topic: Transducer Placement  (Read 11338 times)
Offline Jerzrae
  • Unit(s): 898c, 788ci
« on: April 03, 2010, 03:29:55 PM »
Hey everyone, hopefully I posted in the right section. I am finally entering the sideimaging/downimaging world and have an 898 on its way to my doorstep in the next couple of weeks.  ;D While I am eagerly awaiting its arrival, I have read the manual many times over and am now contemplating on the most optimal placement of the transducer. Here are pics of the back of my boat(not as nice looking as most of your boats I know  :( ).  Hope to hear your suggestions!! Thanks.
« Last Edit: April 03, 2010, 03:31:07 PM by Jerzrae »
Re: Transducer Placement
« Reply #1 on: April 09, 2010, 11:19:49 AM »
Is this the stepped hull (is there a step under the transom that we can’t see in the pictures you posted?)?  If it is not than I would start by getting a transducer mounting board or making one of my own and place the transducer about where the bracket is for the old speed pick-up is on the right side of the motor.
How well does that other Humminbird transducer work?  I ask because you could use it for the 2D sonar and mount the 898’s HDSi transducer up a little higher on the transom to help protect it (they about $275 U.S. to replace).  You would need an AS-Si-DB-Y splitter cable to connect both transducers to your 898 unit.
Last post June 20, 2010, 07:38:02 AM
by IRC Kevin
Last post September 16, 2011, 09:55:49 AM
Last post February 02, 2012, 10:25:51 AM
Last post November 25, 2012, 12:41:58 PM
by Speedtroller
Last post March 07, 2012, 07:01:54 PM
Last post April 03, 2012, 09:47:31 AM
Last post April 06, 2012, 04:29:55 PM
by Brian37075
