Author Topic: Dr.Depth with Ethernet or nmea  (Read 11781 times)
Offline depark1
  • Unit(s): 998CX SI
  • Software: 6.180
« on: February 25, 2012, 11:41:08 PM »
I was wondering what would be the better choice to connect my laptop to my new 998c SI running Dr.Depth, Ethernet or NMEA?  What will give me the most functionality?  Are there times specific to each type?
Darryl
Offline Rüdiger
Re: Dr.Depth with Ethernet or nmea
« Reply #1 on: February 26, 2012, 04:49:07 AM »
Hi Darry
In any case Ethernet, HB NMEA does not work for this ???!!!
Just so, for example, live side scan mosaic possible.
You need a original HB Ethernet-cable that you will share, and then you must press a RJ45 plug onto the free end. The pin assignment can be found in the Help menu of DrDepth.
mvh
Rüdiger
Finding is better than losing
Offline drpelle
    • DrDepth mapping
  • Unit(s): 998
« Reply #2 on: February 26, 2012, 05:44:42 AM »
Hi Darry
mvh
Rüdiger
Not true, HB NMEA works just fine, you just got to connect it the right way (which happens to be through
the 'pigtail'/cable stump comming off the GPS cable plug).
For DrDepth:
- NMEA will give you depth + position data, so if you only want to map depth that's all you'll need.
- If you want live sidescan mosaic and/or live bottom hardness you will need to use ethernet (and
  in that case you do not need NMEA, position data is avaiable on ethernet as well).
Per
www.drdepth.se
Offline Rüdiger
« Reply #3 on: February 26, 2012, 07:54:46 AM »
Hi Per
Give the pigtail real deptinformations ?
mvh
Rüdiger
Offline depark1
  • Unit(s): 998CX SI
  • Software: 6.180
« Reply #4 on: February 27, 2012, 12:27:36 AM »
For DrDepth:
Per
www.drdepth.se
So if I follow then with the Ethernet cable it will give me depth, position, sidescan mosaic and live bottom hardness without needing to connect to the NMEA pigtail on the GPS.  Yes or no?  Making the Ethernet cable will be easy enough.
Last post July 15, 2009, 11:01:58 AM
Last post September 14, 2009, 03:46:29 PM
Last post May 24, 2018, 10:13:38 PM
by Gimp
Last post June 21, 2010, 11:39:18 AM
Last post May 04, 2011, 04:17:29 AM
by SonarTRX
Last post May 24, 2011, 03:04:20 PM
Last post September 12, 2011, 06:17:29 PM
Last post October 08, 2012, 05:15:56 PM
by Iowa
