Author Topic: NMEA Out BUG in Firmware 4.620 !?  (Read 15270 times)
Offline pebe
  • Unit(s): HB 798ci SI
  • Software: 5.450
  • Accessories: AS-GR-HA
« on: September 06, 2009, 06:36:41 PM »
What happend in Firmware Version 4.620 with the GPS Infos in NMEA Out while in the Simulation Mode ?
With 4.510 i got NMEA Out with GPS Info while i am in Simulator Mode.
This means also if i playback a Record i got the right NMEA Out including GPS Position from the record.
But with the 4.620 i got nothing Out while i am in Simulator Mode !
First i thought of an Cable Problem, but when i am in Normal Mode with 4.620 i got NMEA Out from the rcord without GPS Data.
This is the same behaviour like using the 4.510.
But now ????
No way to get the NMEA Out with GPS Information within the Firmware 4.620 ? (Not in Simulator Mode and not in normal mode)
Actually i went back to 4.510 as a workaround.
I dont think that HB wants do disable the GPS Infos in NMEA Out on this way ?
Pebe
Re: NMEA Out BUG in Firmware 4.620 !?
« Reply #1 on: September 14, 2009, 03:46:29 PM »
Saw one of your posts on this on another board and have asked that someone look into it.
Last post April 21, 2010, 05:07:50 PM
by mendota
Last post June 06, 2010, 07:19:31 AM
by Timo
Last post June 21, 2010, 11:39:18 AM
Last post February 28, 2011, 03:30:28 PM
Last post March 29, 2011, 03:12:28 PM
by ZEUS
Last post May 04, 2011, 04:17:29 AM
by SonarTRX
Last post May 24, 2011, 03:04:20 PM
Last post February 03, 2012, 04:24:23 PM
