Author Topic: Ethernet and NMEA  (Read 6975 times)
Offline Rüdiger
Ethernet and NMEA
« on: September 11, 2011, 06:25:00 AM »
Hi specialists
Is it possible to use Ethernet-out and NMEA-out on the same time ?
I have test it and it does not work.
mvh
Rüdiger
Finding is better than losing
Re: Ethernet and NMEA
« Reply #1 on: September 11, 2011, 09:40:53 PM »
Rudiger,
I have not tried it, but you should be able to use the raw NMEA coming off the GPS vs the NMEA out from the unit.  You just wont have the depth string.
Check your pigtail connections and see if you have the new GR50.  There was a post a few weeks ago that talked about this.  I will try to find it.
Offline Rüdiger
« Reply #2 on: September 12, 2011, 10:50:35 AM »
Thanks Robert
Yes i have the GR50 receiver and normally i use the HB-ethernetfunktion for DrDepth and the NMEA-output from my EAGLE unit for real depth and position information for my navigation software.
It was only a test to use the NMEA-output via AS PC2 cable and it does not work.
mvh
Rüdiger
« Reply #3 on: September 12, 2011, 06:17:29 PM »
There is a new pigtail configuration in the NEWER GR50s that came out this year!
Last post June 21, 2010, 11:39:18 AM
Last post May 04, 2011, 04:17:29 AM
by SonarTRX
Last post May 24, 2011, 03:04:20 PM
Last post February 03, 2012, 04:24:23 PM
Last post April 11, 2012, 10:22:08 AM
Last post February 27, 2012, 12:27:36 AM
by depark1
Last post April 10, 2012, 07:38:45 PM
Last post July 21, 2012, 10:46:47 AM
by erocks4u
