Author Topic: How do I check what software version is on my unit?  (Read 24507 times)
« on: March 29, 2009, 05:32:46 PM »
Taken from Humminbird.com Top 5 Frequently Asked Questions
Checking Software Version
There are currently two ways in which you can determine the software version of your Fishing System unit
#1. Connect your Fishing System unit to your PC and use the “Get Unit Profile” feature of the HumminbirdPC program to display the “S/W Revision”
#2. Follow the steps below:
Power your Fishing System unit on. This can be done while on your boat in or out of the water or with power only connected to your Fishing System unit.
While your Fishing System unit is displaying the model number, press the Menu key. Example: your Fishing System unit is displaying “Humminbird 767 Fishing System”.
The display on your Fishing System unit should change to show you four menu options: “Normal”, "Simulator”, “System Status”, and “PC Connect”. With the four way key, use the Down Arrow key to select “System Status”.
The Fishing System unit will ‘time out’ and will display the System Status View. The software version is listed under “Software Version”.
How To Tell What Version Of Software You Are Running In Your Unit
« Last Edit: August 06, 2011, 03:41:25 PM by RGecy »
Last post February 01, 2013, 04:23:48 PM
by Jim Jack
Last post January 31, 2015, 12:55:13 PM
Last post January 19, 2015, 04:53:02 AM
Last post February 16, 2015, 08:57:15 AM
Last post December 17, 2015, 04:03:34 PM
by Beaulieu80
Last post December 26, 2016, 07:34:48 PM
Last post April 02, 2017, 10:29:05 PM
