Author Topic: 798 HD SI DUAL SETUP  (Read 10243 times)
Offline mt72916
  • Unit(s): 798 565
« on: February 05, 2011, 10:43:51 PM »
One of the possibilities I am considering is mounting a 798 HD SI on a ram mount at the console and at this time I can only afford one head unit.  I understand that I need to mount the SI transducer to the jack plate and a 2d transducer in the bilge for high speed 2s sonar and a “Y” cable for just the console configuration.
 What would I need to order for an extra setup to set this unit up to move it to the bow on the trolling motor? I would like DI an 2d sonar at the minimum there.
Re: 798 HD SI DUAL SETUP
« Reply #1 on: February 09, 2011, 04:59:40 PM »
That depends on what you want to do for the transducer: mount a second CSi transducer on the trolling motor or use the ones you already have on the transom (and inside-the-hull)?
For both you will need:
PC-11 Power Cable
MS-M Quick Disconnect Mount
To install a second CSi transducer you will need the XTM-9-Si-180-T transducer.
To use the transducers you have you need a Unit Switch US2-W.
Offline mt72916
  • Unit(s): 798 565
« Reply #2 on: February 09, 2011, 07:45:17 PM »
well after much studying and agonizing
I bit the bullet today bought these from BBG Marine
this is my first color unit
Humminbird 798 ci HDSI  #407970-1
Humminbird XTM-9-HDSI-180-T
Navionics hotmap Premium South
Mount case covers MC-W
AS SIDB Y splitter cable
Ram mount Ram-107U
DBK2 2nd station ducer kit
just going to swap head unit positions as necessary
plan to swap at humminbird the std compact transducer for XHS-9-HDSI-180-T  for the transom
and also swap the MS-M for the  MS700-E  2011 798 HDSI mount
and i should already be set up for an upgrade extra CHO someday.
just got to get some tranducer shield products now.
« Last Edit: February 09, 2011, 07:46:40 PM by mt72916 »
Last post March 28, 2010, 10:23:22 AM
Last post January 03, 2011, 01:12:25 PM
by keizerh
Last post April 17, 2013, 12:07:25 PM
by Kokanee
Last post May 28, 2013, 12:27:17 PM
Last post February 24, 2014, 07:46:07 PM
Last post March 04, 2014, 02:20:50 PM
by Planokeith
Last post April 21, 2014, 02:33:32 PM
Last post April 25, 2014, 02:31:50 PM
