Author Topic: AS GPS HS setup  (Read 9411 times)
Offline marinero
    • Search and recover
  • Unit(s): 981cx SI
  • Software: 4.950
  • Accessories: GRHA
AS GPS HS setup
« on: May 28, 2013, 04:04:46 AM »
Gents,
I try to set up the HS and I have couple of questions.
can the surface for installing the Gps HS be flat and parralel to waterline?
or may a little slope on the surface be present? As for my boat, it is about 7° from transom to bow along the side.
Recently I tested HS with 1198 and the estimated pisition error was.. 0.3m. I was amused.
when I attached GR50, the EPR was 1,5-2 m. on water.
Thanks.
Offline marinero
  • Unit(s): 981cx SI
  • Software: 4.950
  • Accessories: GRHA
Re: AS GPS HS setup
« Reply #1 on: May 28, 2013, 09:22:17 AM »
When I do this experiment with my tablet PC with Heading Sensor, I slop until 15-20° and the indication of direction is still :)
It is because the HS in my tablet is 3-axis. I think the HS in AS GPS HS the same. Any ideas?
Re: AS GPS HS setup
« Reply #2 on: May 28, 2013, 10:13:44 AM »
I would think that you would want your gps receiver to be
as flat as possible against the sky.
Even so, most satellites will probably be hitting the puck from
an angle.
But, that is the way it is designed to work.
Offline marinero
  • Unit(s): 981cx SI
  • Software: 4.950
  • Accessories: GRHA
Re: AS GPS HS setup
« Reply #3 on: May 28, 2013, 10:25:44 AM »
as fof sattelitas I quiet, I worry about heading sensor readouts.
Re: AS GPS HS setup
« Reply #4 on: May 28, 2013, 12:27:17 PM »
I’m trying to check on a maximum angle for mounting the GPS-HS but so far have not heard anything back.  I would think that a 7 degree incline would not be a problem though as many boats will roll more than that during normal operations.
Last post February 09, 2011, 07:45:17 PM
by mt72916
Last post December 23, 2011, 05:46:26 PM
by tommyboyrn
Last post August 19, 2012, 12:24:12 AM
by stratofisher
Last post February 24, 2014, 07:46:07 PM
Last post March 04, 2014, 02:20:50 PM
by Planokeith
Last post April 21, 2014, 02:33:32 PM
Last post April 25, 2014, 02:31:50 PM
Last post April 02, 2015, 11:20:47 PM
